Old October 15, 2011, 02:29 PM
Default Some thoughts about case fans.
One thing I was thinking about today just based on ease of working around on and cleaning etc. I'm surprised someone hasn't come up with a magnetic system for case / radiator fans. Recycled HDD magnets would work. Lord knows I have a bunch of dead HDDS laying around ;) Never mind all the IDE drives i'll never use again. All you would really need is flat steel screws and then some way of shaping and attaching the magnets to the fans.
Thoughts?
Old October 15, 2011, 03:04 PM
JD JD is online now
You mean using magnets to attach fans to the case? I don't think that's the greatest idea having magnets that close to other components...On a radiator, maybe, but within the case, no.
You can get fans with removable blades which makes cleaning rather simple. Also most cases have filters on intake fans now-a-days which also helps make cleaning easier.
Old October 15, 2011, 03:13 PM
ipaine's Avatar
Just so I understand what you mean, are you talking about attaching fans to the case with magnets?
Basically as kind of like some sort of "quick release" method for ease of cleaning?
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old October 15, 2011, 05:22 PM
Shadowmeph's Avatar
Hmm Magnets and PC Hardware are not a good Mix , you could always just use Velcro tape strips that is what I did when I was on Air
Old October 15, 2011, 07:22 PM
Magnetism issues are a little blown out of proportion here, you'd need very strong rare earth magnets touching the actual hardware to cause any issues. Magnets on the case are honestly a non issue.
Gelid Wing fans will hold their own weight and stick to steel cases without much difficulty. (only on one side of the fan though) The magnet they use to hold the bearing is very strong. Enermax fans with their "Twister" bearings will stick as well, but on the other side of the fan.
Old October 16, 2011, 10:47 AM
Soultribunal's Avatar
Gotta agree with ilya on this one as well. There are a lot of magnets in case doors and sometimes side panels (old TT cases) that have never caused an issue. Unless you are taking a magnet right beside your HDD or on some components on the board you should be fine.
ST
Old October 17, 2011, 07:31 AM
Yep pretty much. I water cool so when I wanna get in there and blow out the rad it would make it nice to just yank it off blow it off and put it back on again. And magnets holding fans in place really isn't going to affect any other parts. You'd need HDD quality magnets stuck on the top of working/running hdd to screw anything up.
And I mean magnets in place of screws. I have some dead hdds I might take them over to Brains place and try making a proto type. You wouldn't want weaksause magnets imo.
Old October 17, 2011, 09:58 AM
Yeah that sounds like it would work and its actually a pretty good idea, However aren't most Rads made of Alumium and therefore not a Ferrous Magnetic Metal? Or are you going to put anchor points on the rads for the Magnets to attract themselves to?
Let us know how it works out!
Brain is a pretty cool mad scientist too here,
ST
Old October 17, 2011, 10:10 AM
chrisk's Avatar
Folding Captain
I think a good solution would be a 'quick release' plastic or even metal system. I have wondered why case makers/rad makers would not develop a mountable plastic shroud that attaches to the case, holds the rad and fans in place, and with some clamps released the rad and fans would be detached.
Fold for team #54196
Old October 17, 2011, 10:42 AM
I agree 100% on this Chrisk, TT and Ultra had them for Fan Holders on their cases, made it really easy to swap out or pull out and clean vs having to thread thme in with fan screws.
ST
Got a too many fans for my case, help me pick which to keep 0o0 Air Cooling 8 March 19, 2010 07:52 PM
80mm case fans dante1 Air Cooling 3 January 17, 2010 03:32 PM
Case fans to MB or PSU? ontariodude Guides & How-to's 14 September 28, 2009 01:31 PM
Case Fans? chouchou Air Cooling 3 October 24, 2008 06:49 PM
suggestions for case fans..... rob123 Air Cooling 18 August 13, 2008 08:19 PM
