Originally Posted by clshades A drill press works really good too shadow ;-) I'll have to spend some time over at Braineaters place to muck around. I thoughts on vibration control would be the same things you use on cupboard doors. The little plastic sticky things. HDD magnets are pretty strong and yes Soul... I would try and find some decent flat steel screws and put them on 1st. |
Makes sense actually if you got the bigger ones and put little rubber or felt pads on them it will dampen it quite well. There are also LOTS of rubberized coatings around that would be useful too.
Can't wait to see you cook up a prototype.
ST
