Old October 5, 2011, 06:37 AM
Avenger212's Avatar
Default Fractal Design Define XL replacement Fans Recommendations
Hello
I recently replaced my old Aerocool case with a Fractal Design Define XL. So Yesterday I bought a new Fractal Design Define XL, but the noise from the fans is driving me nuts. I also can't get the fan controller to work. So I would like to ask any recommendations to replace these annoying 140mm Fans and a new fan controller?
Old October 6, 2011, 12:44 AM
Prolab's Avatar
Well, ideally - if you just bought the case a few days ago and the fan/fan controller not working, id take it back and exchange it.
But if you cant exchange it, well you can replace your 140mm fans with Noctua's or even Xigmatek ones. Both is fairly quiet (IMO anyways) and move decent air.
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old October 6, 2011, 08:38 AM
Nexitus's Avatar
I actually found that 140mm to be quite acceptable in my Define XL.
I actually tried replacing the front cover with 2x Thermalright Silent-X fans. They just didn't fit, don't even try because you'll end up breaking the damn thing.
Try the Noctuas
Old October 6, 2011, 09:47 AM
You can easily get free replacements from Fractal or the retailer. However my experience with them has been pretty bad, a half dozen free replacements and 5 of them had that annoying buzz/click.
Old November 26, 2011, 09:19 AM
Lsv's Avatar
Lsv Lsv is offline
Try the Noctuas
Noctua's all the way. I don't think I'll ever use anything but them for quite some time.
i7 920 (no oc) w/ Noctua NH-D14
Asus P6T
Asus 6950 DC II 2gb
12gb G.Skill Ripjaws 1600mhz
Intel X-25M 80gb Gen2
2x WD Caviar Green 1TB 64m cache
2x WD Caviar Green 2TB 64m cache
Native Instruments Komplete Audio 6
Seasonic X-660
Fractal Design R3 + 4x Noctua S12B 120mm
Old December 2, 2011, 11:29 PM
Zer0's Avatar
Hey everybody.. first post here.
These are fans I got to replace the ones in my XL. I've spent a few hours looking for the right fan that matches the black and white scheme and has decent airflow and noise level. I haven't received them yet, hopefully by next week.
XIGMATEK
Old December 2, 2011, 11:34 PM
Avenger212's Avatar
I thank you all for your recommendations but this issue had already been resolve. Again Thank you
Fractal Design Define R3 or similar limitedaccess Cases 8 January 23, 2011 06:12 PM
Fractal Design Launches Define Mini FiXT Press Releases & Tech News 5 December 30, 2010 02:10 PM
Fractal Design Define R2 - Black Pearl mattlef Cases 97 July 26, 2010 02:34 PM
Fractal Design Define R2 Case Coming to North America - Exclusive Launch Details! FiXT Press Releases & Tech News 27 April 21, 2010 01:02 PM
Fractal Design - Define R2 - Member Review mattlef Member Reviews 18 March 4, 2010 12:29 PM
