Old March 14, 2010, 11:09 AM
No, I have not used those coolers personally. I can tell you for certain that even the stock cooler is perfectly fine since you won't be overclocking, but if you really want something better, just about any aftermarket heatsink will do. That's why I think the best course of action would be to go with one of the less expensive good heatsinks and one that has a good and simple to use mounting system.
Old March 14, 2010, 11:12 AM
I am using this cooler for an older SM PDSLA board, keeps the old Prescott 3GHz CPU running about 35 DegC
Enzotech Extreme-X Rev. A 120mm Fan Quad Heatpipe Universal CPU Cooler (Intel & AMD)
Newegg.com - Enzotech Extreme-X Rev.A 120mm 2 Ball CPU Cooler - CPU Fans & Heatsinks
Out Of The Inner Circle
Old March 14, 2010, 11:17 AM
again, thanks, its aways good to have anothers input.
BTW, most of the heatsinks I use, I machine groove down the center of said heatsink to monitor the CPU case temp mating surface at the heatsink and CPU, then compare the delta temp of the chip die temp to the case. As you can see, I don't mind the extra work
Old March 14, 2010, 11:23 AM
chrisk's Avatar
Folding Captain
you didnt see anything.....
Fold for team #54196
Old March 14, 2010, 11:27 AM
Look at the date, Chris ;).
Old March 14, 2010, 11:29 AM
use teflon stand-offs and you won't scratch the mother board
chrisk's Avatar
Folding Captain
Ahahahaha...
Old March 14, 2010, 11:55 AM
Technically you're supposed to machine a groove into the CPU heatspreader, not the heatsink. I think it's cool that you actually bother to do it though.
  #19 (permalink)
Old March 14, 2010, 02:00 PM
Since most CPU Heatsinks sits on top of the CPU Heatspreader, and most users don’t lap the CPU Lid and or heatsink for flatness, it serves no purpose cutting into the heat spreader when I’m interested in the Delta difference between the center of the heat spreader and the mating surface of the heatsink, I have also placed other thermocouples within the heatsink block mm from the mating contact surface, on top of heatsink block about center over the CPU and mid way up the Cooling Fins to review these Delta changes as well. Tho the use of Thermal epoxy for the Thermocouples does add to the slow rate of data change and the thermal conductance resistance.
There is a paper written about this under, Thermal Management and Heatspreader Qualification, where I found this method of testing.
I just had to buy the TC and equip and do the machining work on a bought heatsink from Newegg
  #20 (permalink)
Old March 14, 2010, 02:06 PM
Out of curiosity, what do you do?
Noctua NF-P12 Comment Thread SKYMTL Water Cooling 32 January 30, 2009 09:40 PM
ATI HD3870 X2 1GB Comment Thread SKYMTL Video Cards 126 June 7, 2008 08:11 AM
Comment thread for MM U2-UFO worklog Babrbarossa Water Cooling 38 June 3, 2007 03:24 AM
Cooljag Falcon 92-Cu Heatsink Review by FrostyTech Babrbarossa Reviews & Articles from the Web 5 May 22, 2007 06:03 PM
