Old September 21, 2011, 04:01 PM
Default Monitoring temperatures
Hi all. I am wondering how do I monitor my CPU temp without going into the BIOS? I would like to check what my temps are because I just installed a Corsair H60 and used the motherboards easy overclock utility.
Old September 21, 2011, 04:05 PM
I like Hardware Monitor
"What is the colour when black is burnt ?" - Neil Young
Old September 21, 2011, 05:41 PM
Ok I downloaded HW Monitor. Is 34C min and 50C max safe temperature ranges? I got those readings after a quick Starcraft II match.
Old September 21, 2011, 05:51 PM
techman95's Avatar
well it depends your running an i5-2500k right?so what was it overclocked to and what was the voltage it took to get there
Old September 21, 2011, 05:56 PM
Yes correct. i5 2500k. It wasn't previously overclocked it was just how it came. This is my first build which I set up a little under a weed ago.
I decided to try out the easy 1 click overclock from my motherboard. I'm using an ASRock P67 Extremem4 Gen3. It's like a turbo boost function? I decided to try it with the lowest setting to clock it up to 4.0 ghz. Nothing seems to be acting funny so far. I didn't want to try any of the higher settings because I'm str8 n00b y0! sorry the 1998 online gamer in me took over for a second. :)
Old September 21, 2011, 06:14 PM
SugarJ's Avatar
Take a look in here: http://www.hardwarecanucks.com/forum...ols-trade.html
I use coretemp myself, as it has a plug-in for my G19 keyboard. My temps are always onscreen.
Old September 21, 2011, 06:53 PM
Supergrover's Avatar
Are you using HWMon or Open hardware monitor?
Open Hardware Monitor - CPU Temperature, Fan Speed and Voltages in a Free Software Gadget
I find the gadget function in open to be great.
R.I.P.
Old September 21, 2011, 08:10 PM
CPUID's HWMonitor.......
still noone said if that is a safe temperature.
Old September 21, 2011, 08:14 PM
Shadowmeph's Avatar
Wow nice piece of software I like it
Old September 21, 2011, 09:16 PM
50c at load for a 2500 is perfectly fine.
R.I.P.
HDD temperatures? phoenixrage Storage 3 July 23, 2010 11:14 AM
5770 Temperatures NineLives Video Cards 4 July 8, 2010 12:33 PM
Temperatures on an x2 555 poroporo Overclocking, Tweaking and Benchmarking 3 May 14, 2010 07:27 PM
Overclocking + Temperatures rocklobster Overclocking, Tweaking and Benchmarking 11 March 19, 2010 11:14 PM
What temperatures are your HDD? Silvgearx Storage 10 January 31, 2009 04:33 PM
