Yea you should use a 2nd fan. Currently I am using a Megha with 2 blademaster fans in push pull config and at 4.6ghz at i7 2600k @1.36 v I dont hit 60 degrees at prime 95 or much brutal LinX
Originally Posted by Pabz0r545 Thanks for the info sherbanater. Unfortuantely I have already installed a corsair H60. Hopefully someone else will be able to use the info though.
53c is pretty nice max temp from prime 95. Do you have your CPU overclocked?
I am getting 60c max at 4.2 GHz with the H60. I am going to install a 2nd fan on the H60 for a push pull to see if it makes much of a difference, but first I have to get off my lazy ass to the hardware store to get some screws. |
