Old September 16, 2011, 08:27 AM
Default fan suggestions for hsf/case
so it seems that my yate loons D12SL-12 (push/pull on hsf and rear) ... i also have a scythe kaze server fan controller if the fans ever get too loud
i would like some suggestions which fans for the following function:
120mm - HSF push/pull (VenX) and Rear Exhaust
Ive been reading some reviews and doing some research and narrowed it down to the following:
120mm - ZM-F3, SY1225SL12M, SFF21E/F, D1225C12B4AP-13/14
any suggestions and insights would be appreciated.
thanks
Old September 16, 2011, 09:27 AM
I do not know the model by heart but the stock 140s that come with the silver arrow HSF are amazing, nearly silent and move a lot of air around.
Old September 16, 2011, 10:27 AM
interesting.. the 140mm fan with 120mm retention holes... so they would fit with regular 120mm rear exhayst no probs? (ie without mods)
Old September 16, 2011, 11:03 AM
Depends on how much clearance you have in your case. The 600t doesn't look like it's wide enough, especially if you want to use the TY-140 mentioned by the previous poster.
Given your current fan choices, I would assume you're trying to go for lower cost fans with good performance. In that case I wouldn't recommend any of them, especially the Yates. Go for CM R4's and undervolt them. They can be had for $4-$5 a piece quite easily.
mATX Case Suggestions Inik Cases 20 January 29, 2011 01:18 AM
need a new case suggestions? severity Cases 0 December 22, 2010 11:27 PM
Case suggestions for a unique set up Arinoth Cases 10 June 26, 2010 09:31 AM
open air case suggestions gingerbee Cases 5 March 28, 2009 05:57 AM
Need Case suggestions Jackquelegs New Builds 19 August 23, 2008 01:16 PM
