Old September 10, 2011, 05:43 AM
I use the TR silver arrow (similar in size) on my 2500k rig and if you run only 2 sticks they should fit without being tucked under the sink( that is if you put the fan on the exhaust side).
Old October 28, 2011, 08:42 PM
I have an ASUS P8P67Pro and want to get the Noctua HS, I have 4 sticks of RAM but its standard height Mushkin brand so will it fit?
Did you try turning it off and on again?
Old October 28, 2011, 09:20 PM
AkG's Avatar
AkG AkG is offline
Hardware Canucks Reviewer
As long as its standard height ram you shouldnt have a problem (as long as you install your ram FIRST that is). Its designed with std height ddr3 ram in mind. ;)
TBH, its only when you get into the ram with fancy (and IMHO useless) and tall heatspreaders that you run into problems with this beast. Still prefer a Corsair H80 to the D14 but for air the D14 is a beast. :)
Old October 29, 2011, 01:08 AM
totally agree with u on all accounts but one (actually double checked the poster to c if i wasnt reading my own post after u called gimicky ram useless). Thing is the D14 out performs the H80 and ties with the H100 and is much more silent. Only advantage H80 has is compatibility and if u go with the equivalent performing H100 u even loose on that...just my 2 cents (you can disagree, some people just want Hseries to be able to say they have water cooling or simply hate noctua fan colors including me...but temp/sound benchmarks are all in favor of the D14)
Old October 29, 2011, 07:27 AM
CoolHandL's Avatar
I love my Noctua cooler, I have all 4 ram slots filled, mind you they have heat spreaders but the kingston kind ie low profile
Old October 29, 2011, 11:05 AM
yycraven's Avatar
Its a great cooler keeps my X3440 at 60C load , but like everyone said, make sure your ram is low profile.
http://www.hardwarecanucks.com/forum...a096d5beb1.jpg
this is my set up with the Noctua NH-D14.
Old October 29, 2011, 03:52 PM
Ok I bit the bullet and purchased and installed the NH-D14 today, the thing is a beast but it fits without any issues with my 4 sticks of ram.
Old November 9, 2011, 01:56 PM
Soullessone21's Avatar
The Noctua Coolers are amazing if I didnt go water cooled I would be using my old one now, They are huge though I like using the Chaser MK-I with mine so theirs lots of space but you can fit them in a small case like the V3 V4 from thermaltake its just a tight fit haha
  #19 (permalink)
Old January 12, 2012, 08:43 AM
Trial Member
I found this post via Google.
I've had an i7-975 extreme core since 2010, and shame on me, am just now looking to clock it up some.
Anyway, I just purchased an NH-D14 and wonder how it will fit with my Patriot Sector 5 memory. I have all 6 slots filled on an Asus Rampage Extreme III Gene mobo. If they don't fit, I can simply trim (cut off) the heat spreaders on a stick or two, or alternately, get the NZXT Havik (Overclock3D :: Review :: NZXT Havik vs Noctua NH-D14 Review :: NZXT Havik vs Noctua NH-D14 Review) which is cheaper, has similar (a touch louder) performance. Thankfully NewEgg is the best when it comes to speedy returns and exchanges.
  #20 (permalink)
Old April 3, 2012, 09:10 PM
I just bought one to replace my Prolimatech Megahalem. Will place it into my new NZXT Switch 810 case and see how well it does. Can't wait to test this baby out!!
[FS] Noctua NH-D14, Noctua NC-U6, Thermaltake Spirit RS alexroland Buy/Sell & Trade 1 April 11, 2010 01:09 PM
[WTT] 2x Noctua NF-S12 for 2x Noctua NF-P12 Chos3n Buy/Sell & Trade 2 April 7, 2009 06:11 AM
cheap ssd's anygood gingerbee Storage 13 March 10, 2009 01:17 PM
Noctua-News: Noctua introduces NH-U9B CPU cooler Scotch Tape Press Releases & Tech News 1 February 25, 2008 07:33 AM
