Old September 1, 2011, 02:43 PM
Default I recently installed a hyper 212+ but it does not fully cover my 955BE
Is this okay?
there is about 1-2 mm of the cpu sticking out on 2 sides of the heatsink while one other side is perfect and the other overlaps just a tiny bit
Other Info:
Temps Before 212+ Idle ~35 Load ~53
Temps After 212+ Idle ~30 Load~43
It seems to be working fine, but i dont know if it will cause long term problems or problems at all so i wanted to check in on it.
Old September 1, 2011, 03:04 PM
ideally the more surface contact the better(given the thermal interface material is up to the task)
but yes,to answer your q. youre good. :)
the mroe you push your cpu,the more difference the third party cooler should make.
Old September 1, 2011, 03:11 PM
sweet! thanks, im just making sure, i think it probably has something to do with the motherboard as to why it doesnt sit right
Old September 1, 2011, 04:12 PM
unless something is warped, not as intented, once you tight it,well,screw it down it should not move much and be quite straight,whichever way it is facing.
take a pic,but if your temps are in check do not worry.
Old September 1, 2011, 04:38 PM
maverick_brent's Avatar
Your just seeing the heat spreader but the hsf its actually covering the processor chip..the integrated heat spreader is just a piece of the processor that goes over the actual cpu to spread the heat over a larger surface area this wasnt a problem back in the day but as the die size shrank we lost surface area to cool the cpu thus began the ihs ..my 212 is the exact same...
stupid phone and auto correct
Heat spreader - Wikipedia, the free encyclopedia (explanation)...
http://download.intel.com/pressroom/...otate_Logo.jpg (visual reference)
Old September 1, 2011, 10:11 PM
like he said the actually cpu is in the middle...under the cover
and the temp differences would tell me its working properly
they used to do it without the cover and you'd put the heatsink right on the cpu
however ... i guess too many ppl were breaking the cpu so they stopped doing it, or better heat displacement with the cover
intel had a cover for years already, before AMD did the same
Old September 3, 2011, 10:24 AM
The die is much smaller than the aluminum cover, so as long as it covers the middle it is fine.
No physix drivers installed after I installed them? Help!! bushwickbill Video Cards 8 February 14, 2013 07:23 AM
cpu always at 100% for no reason recently cozmosland Troubleshooting 34 August 28, 2011 06:11 PM
Suggest me some new movies that recently came out? Blu Off Topic 14 May 9, 2011 09:06 AM
x4 955BE worth $135 now? upcoast604 CPU's and Motherboards 1 February 9, 2011 10:37 AM
Have you purchased an EPSON product with a mail-in rebate recently, READ HERE DarKStar Off Topic 4 November 27, 2008 07:25 PM
