Old August 19, 2011, 09:57 AM
Talking Coolermaster Hyper 212+
I knew these coolers where big, but not this big............... its HUGE.
It just fitted in my case by 2mm from the side panel.
Ive ordered another Coolermaster Blade Master 120mm, for a push/pull setup.
Casecom 6788/Rosewell Challenger
Old August 19, 2011, 10:02 AM
yeah they are pretty tall. shorter than the corsair ones though, and thats where they win sales.
not to say they've been selling them for years ;)
did you measure your case with the cm schematics in mind when you bought it?
Old August 19, 2011, 10:06 AM
No I didnt measure so to say, I done it by eye.
I wasnt planning in fitting it just yet, as Im saving up far a HAF 932.
Old August 19, 2011, 10:14 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Why do you have your mem installed like that? Is that dual channel on whatever board that is?
Old August 19, 2011, 11:16 AM
Keltron 3030's Avatar
Some of the ASUS boards do RAM like that; It's like that on my board as well
FFFFFFFUUUUUUUUUUUU-
Old August 19, 2011, 11:25 AM
invest the 932 budget in a better gpu or something. :)
edit : scratch that,you already have a nice gpu.
if you have to, maybe get the 912? at least half the price and still a lot of bang for the buck.
been using them by the truckload
Old August 19, 2011, 10:02 PM
i have a HAF 912
the cooler fits in there with lots of room as well
has really good cooling results as well
Old August 19, 2011, 11:04 PM
supaflyx3's Avatar
Mine also fit by about 2mm, but it isnt that big of a cooler really, lots are bigger
Old August 20, 2011, 04:40 PM
Got to say im impressed with this cooler.
The pc runs so cool, compared to the Artic cooler.
Old August 20, 2011, 06:01 PM
supaflyx3's Avatar
wow dunno how you got yours so cool, my 940 runs at around 50 idle on my H50, about 55 on my 212+ at 3.6.
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 76 November 4, 2013 06:42 AM
coolermaster hyper 212+ on Asus p8h67-m LE motherboard beginnerbuild Air Cooling 1 April 26, 2011 04:51 PM
CoolerMaster Hyper 212+ nikokapo Air Cooling 4 September 8, 2010 06:30 AM
CoolerMaster Hyper 212+ performance on i7 marstedt Air Cooling 8 May 30, 2010 12:15 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 04:56 PM
