  #21 (permalink)
Old August 21, 2011, 06:29 AM
supaflyx3's Avatar
weird, it reads my CPU just fine.
  #22 (permalink)
Old August 21, 2011, 01:39 PM
EmptyMellon's Avatar
Arrow Try disabling the Core Unlocker in the BIOS
Checking out some other forums, you might have to disable the Core Unlocker in BIOS, for the temp's to show up in Windows.
  #23 (permalink)
Old August 22, 2011, 07:10 AM
^-- what he said
i had the same problem of temps not showing
my 955 runs cool as well even when i overclocked it
not sure why your temps are so high superfly
  #24 (permalink)
Old August 22, 2011, 08:03 AM
mmm, Il try this when I get back home.
  #25 (permalink)
Old August 22, 2011, 02:23 PM
In my bios it was 'unleashed mode' that has to be 'disabled' and it will show the core temps.
So after 10mins on prime95, its just a quick test to see if temps work.
  #26 (permalink)
Old August 22, 2011, 02:43 PM
supaflyx3's Avatar
Pretty good temperatures, what's your ambient at?
  #27 (permalink)
Old August 22, 2011, 02:47 PM
Around 26c > 30c, I turned off the heating in the room just before the primetest.
Dont take above post for temps, as it was only ran for a few mins.
It was just a test to see if I could get the core temp stats working.
Il get a proper test results done in the morning, Im hoping my new fans arrive aswell.
  #28 (permalink)
Old August 22, 2011, 04:28 PM
Well, the main thing is that you now got it showing the proper temp's, now. Looking forward to your results. :)
  #29 (permalink)
Old August 23, 2011, 03:23 AM
Results are in after 1hr on primetest95
The fans have arrived,
2x CoolerMaster Excalibur 120mm High Air Flow Case Fan - side of case
1x CoolerMaster Excalibur 120mm High Air Flow Case Fan - top of case
2x CoolerMaster Blade Master 120mm Silent Case Fan 12cm - push/pull on cpu cooler
1x CoolerMaster Blade Master 120mm Silent Case Fan 12cm - rear exhaust
1x Standard case fan that came with case - front of case
'Unleashed Mode' - turned OFF in the bios - so cpu temp's can be monitored.
Room temp varied from 28c upto 31c
Im still tweaking the settings in the bios, so Im running at 4070mhz
The cpu fans are connected to a Akasa silent smart pwm cable
  #30 (permalink)
Old August 23, 2011, 04:02 AM
Those are nice temps! I can't even get my temps like that on 3.8ghz. Out of curiosity, do the fans on the side of your case exhaust air out of the case, or are they blowing air in the case?
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 76 November 4, 2013 06:42 AM
coolermaster hyper 212+ on Asus p8h67-m LE motherboard beginnerbuild Air Cooling 1 April 26, 2011 04:51 PM
CoolerMaster Hyper 212+ nikokapo Air Cooling 4 September 8, 2010 06:30 AM
CoolerMaster Hyper 212+ performance on i7 marstedt Air Cooling 8 May 30, 2010 12:15 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 04:56 PM
