Old August 15, 2011, 11:05 AM
ultraman7k's Avatar
Default cooler master 200mm
anyone had any experiences with this 200mm cooler master fan?
i have a 120mm cm r4, and it only has a 3 pin that also powers the LED, is the 200mm the same?
thinking of adding it on the side of my tt chaser as a vga cooler.
Old August 15, 2011, 12:03 PM
It uses a 3-pin and also comes with a 4-pin molex connector.
Old August 15, 2011, 12:43 PM
Soultribunal's Avatar
They work the same way on the 3 Pin, and are powered LED.
Not bad fans, I can hear them but then again teh case has 3 so...
They do do a good job in the airflow department however.
ST
www.realhardwarereviews.com
Old August 15, 2011, 01:06 PM
ultraman7k's Avatar
wait, so is the molex connector optional then?
Old August 15, 2011, 01:16 PM
Yeah. The fan comes with a 3-pin by default, but it also includes one of the molex adapters in case you want to use molex over the 3-pin.
Old August 15, 2011, 01:28 PM
ultraman7k's Avatar
awesome. that is perfect for my case.
thanks.
Cooler Master Announces CM Storm Strike Force 19 Gaming Notebook Cooler FiXT Press Releases & Tech News 3 October 26, 2010 01:48 PM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
Cooler Master Hydra 8800 GPU cooler (water block?) discussion thread Misoprostol Water Cooling 9 December 8, 2007 12:27 AM
