Old August 11, 2011, 07:34 PM
Your_friendly_gamer's Avatar
Default Prolimotech Armageddon fans
Hey all, I have used a few cpu coolers, hyper 212, titan fenrir, fenrir xmas edition, prolimotech megha. And recently I just took advantage of the ncix sale for an Armageddon and was wondering whcih fans should I use. I am thinking of either getting Enermax T.B.Vegas Duo Blue&Red UCTVD14A 140x140x25mm (700-1500rpm) (15dBA) Twister Bearing Chassis Fan | Canada Computers or noctua 140 mm fans. If there is something else please let me know. I would like to get two fans for push and pull config.
Currently I am running megha with two cooler master blade master fans, which have been keeping my cpu's pretty damn cool.
Thank you!
Old August 11, 2011, 07:44 PM
The Noctua isn't compatible with the fan clips used on the Armageddon. (well they fit if you force them, but not very well)
I'd suggest something like the Thermalright X-Silent 140, fairly cheap after PM at NCIX and very good noise/performance. Only issue is the small voltage range.
My experience with the Enermax Twister bearings has been fairly poor, I find that the bearing noise often increases as you undervolt the fan. Making it pointless to run it at anything other than stock speeds. It's basically a hybrid ball/sleeve bearing design like the ones used on the Gelid Wing fans, except Gelid does a better job in terms of implementation.
Don't expect much of a performance increase over the Megahalems though, the Armageddon was not intended to be a high performance heatsink but a lower noise heatsink with fairly good performance.
Red Faction: Armageddon! draemn Gaming 14 October 13, 2011 01:05 PM
Prolimatech Armageddon CPU Cooler Review Comment Thread SKYMTL Air Cooling 11 June 11, 2010 11:18 AM
Prolimatech Armageddon CPU Cooler Released FiXT Press Releases & Tech News 9 June 2, 2010 07:19 PM
[FS] New Zalman fans, used Scythe and blue LED fans mhw100 Buy/Sell & Trade 15 June 22, 2009 02:32 PM
