Fan adapter brackets? 200mm to 180mm
Hey all,
Been trying to google to see if these things exist but nothing comes up. Basically I want to use a 180mm Air Penetrator as a front intake on my case but the mounting holes support only 200mm fans. Is there a bracket or anything that would convert the 200mm holes into 180mm?
I'd imagine it to work something like:
a) the bracket would fit into the 200mm holes
b) the fan would fit into the 180mm holes
Alternatively, does anyone know if Silverstone plans on releasing a 200mm Air Penetrator? I did consider just buying an Antec or CM 200mm fan, but I feel that the AP-181 would yield better performance (not basing it on anything scientific, just a feeling).
Thanks.
