Old July 14, 2011, 08:32 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
Default EVGA Superclock CPU Cooler Review Comment Thread
When someone thinks of EVGA, graphics cards and motherboards are usually the first things that pop into their mind but last month out of left field came their newest product: a CPU cooler. Dubbed the Superclock, it uses an HDT base, has a great looking design, is compatible with every current socket type and sells for under $60. It may sound like perfection but can the Superclock live up to EVGA's reputation?
Read more here: EVGA Superclock CPU Cooler Review
Old July 14, 2011, 08:37 PM
Soultribunal's Avatar
That is very much what was expected from EVGA.
They have great engineering on their first design, however they need to now make the proper adjustments to the design once its out in the hands of the masses.
I for one, would get it just for the looks and because I own a Pletora of High Speed High static pressure fans that will do the job.
ST
Old July 14, 2011, 08:56 PM
very nice.
not bad performance either considering its a 'lightweight' lol.
i like the low speed fan results quite a bit.
Old July 14, 2011, 10:02 PM
Slaughter's Avatar
I won one of these through EVGA's contest but haven't had the time to play with it. It has just been sitting here for a couple weeks now. :P Overall it is a very nice looking piece. Some of the testing is showing decent results.
Old July 17, 2011, 07:24 PM
yycraven's Avatar
Looks like a good after market HSF, low speed fan results are nice as well.
Might have to pick one of these up.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Old July 17, 2011, 07:41 PM
PerryC's Avatar
Nice review. I like the fact that the heat sink is black anodized, but personally I am thinking of a heat sink that can mount two fans.
Old November 24, 2012, 05:43 PM
CTA's Avatar
CTA CTA is offline
hmm not able to find the price for this cpu...
well i guess i will buy Buy COOLERMASTER [RR-V6GT-22PK-R1] Cooler Master V6GT CPU Heatsink Cooler LGA1155 LGA1156 LGA1366 AM3 2x 120mm PWM Fans 800-2200RPM for 50
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
Old November 24, 2012, 06:13 PM
I bought it at NCIX several months back for $11. Best $11 I ever spent. Its discontinued there now, not sure about elsewhere. Amazing cooler. Easy to attach a 2nd fan with just some zip ties.
Cooler Master V10 CPU Cooler Review Comment Thread AkG Air Cooling 60 October 22, 2011 01:52 AM
Cooler Master Hyper 212 Plus CPU Cooler Review Comment Thread AkG Air Cooling 268 April 16, 2010 03:23 PM
Cooler Master V8 CPU Cooler Review Comment Thread AkG Air Cooling 37 June 15, 2009 10:37 PM
Cooler Master Hyper N520 CPU Cooler Review Comment Thread AkG Air Cooling 3 June 8, 2009 07:54 PM
