Old July 11, 2011, 12:51 PM
GT7R's Avatar
From my experience(installed it on a friend's rig), the A70 is actually GREAT. Installation isn't the best, but noise/performance definitively on par with say a Noctua NH-D12.
Old July 11, 2011, 03:21 PM
techman95's Avatar
well i will admit the intel (if thats what it was) mounting for it is better but hes using amd and the a70 on amd is horrible. after having mine for about 4 months on my 925 the ing mount broke sending the damn thing flying into my video card destroying that and plus my temps weren't all that great either probably since it HAD to be mounted north-south sucking hot VGA air so yea that's why i hate the a70 with a passion
Old July 11, 2011, 04:05 PM
a good cooler should be at acceptable noise levels even at 100% load, truth is the v6 isn't that great a heatsink....as a matter of fact its not much different from the H212+ just loaded with 2 crazy fast/loud fans just to put it higher on performance charts...then again the A70 isnt much better for AMD as ur forced to go north-south....
tbh i wouldnt go with either and just go for an armagedon (when it goes on sale for 20-30$ and just pick up 2 nice pwm fans with it) or if you can't w8 for that to happen just go for the H212+ for good temps/mounting or just go super cheap (15$) for a Vendetta 2 keeps my friends 955BE@4ghz at 45C under prime95 load even though it also only mounts N-S!
fact is AMD cpus dont run hot and dont need expensive coolers...just buy something not too loud that is cost effective.
Old July 11, 2011, 07:33 PM
bf1 bf1 is offline
the v6 gt is loud?
if i were to get a hyper 212+ do you think it would be a better alternative if i grabbed 2 fans? if so what fans should i get
are these good?
NCIX.com - Buy Yate Loon D12SL-12 120MM RED/BLACK Fan 1350RPM 47CFM 28DB 3/4PIN Sleeve Bearing OEM Sleeved Retail - Yate Loon - D12SL-12-RED/BLACK - in Canada
Old July 11, 2011, 07:48 PM
techman95's Avatar
it goes back and forth it really depends on the profile in the bios of your board. the gigas have rather good fan profiles im not sure about other brands though
Old July 11, 2011, 08:15 PM
bf1 bf1 is offline
i have a gigabyte 880ga lol
Old July 11, 2011, 09:05 PM
Supergrover's Avatar
For a AMD build you cant go wrong with the 212+ the stock blademaster fan does a decent job out of the box. I was always impressed by the 212+ capability and price, add in a extra fan for pull and you will get even better performance. Kept my unlocked 720 quad @ 1.47v under 60c during last summer using the stock blademaster fan for push and a nfp12 (I think it was last year) for pull.
R.I.P.
Corsair A70 Hacksaw907 Air Cooling 18 July 17, 2011 10:28 PM
Corsair A70 / Crosshair IV midasman New Builds 0 September 23, 2010 01:26 PM
Cooler Master V6GT CPU Cooler jay51 Reviews & Articles from the Web 10 July 8, 2010 03:14 PM
[FS] Lian Li PC-A70 enaberif Buy/Sell & Trade 34 September 14, 2009 07:26 PM
Lian-Li PC-A70 + Water enaberif Water Cooling 13 September 21, 2008 12:41 PM
