  #21 (permalink)
Old February 28, 2008, 11:48 AM
biff's Avatar
Maybe try one of these? I roughly measure the base of the SB cooler on my P965 version to be 32mm square and I think the one on my P35 is the same dimensions. The Zalman is 37mm square so it might take a little creativity. Also the mounts are fully adjustable so no worries about it lining up.
Just a thought.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
  #22 (permalink)
Old February 28, 2008, 12:05 PM
biff's Avatar
I'm not sure I see how the hr-05 SLI would not work on this mobo. Can you give us some details from the email they sent you as to why it won't work? I had a quick look at the drawings on their site and everything seems OK, though I thin you'd lose the use of a PCI slot or two.
Asus P5Q-PRO
EVGA GTX 280 (SC?)
  #23 (permalink)
Old February 28, 2008, 02:39 PM
Mr. Cipher's Avatar
I wrote my post in a poor way. I meant that my Enzotech SLF-1 did not fit my MoBo, so I was unhappy about that and I did not want to try the HR-05 SLI because of the response from TR:
Hi, Paul
HR-05 SLI/ IFX would be pass with 8800GTX.
But if you use the original heatsink on 8800GTX, it may block with the mounted bracket of HR-05 SLI/ IFX.
So I am not quite sure what to make of that. Maybe they want me to buy the HR-03 to cool my 8800gtx while I am at it?
I am going to RMA my SLF-1 and try to get the HR-05 SLI. We'll see if that works...
Again, thanks for all your help and suggestions everyone!
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Ram for a GA-P35-DS3R sircuster RAM 12 April 7, 2008 10:35 AM
GA-P35-DS3R - no bios/boot Mr. Cipher Troubleshooting 5 March 13, 2008 07:25 AM
Gigabyte P35C-DS3R tom.mullie CPU's and Motherboards 7 January 21, 2008 08:06 PM
Reviewer Tryouts: GA-P35-DS3R Mr. Cipher Member Reviews 10 November 20, 2007 07:20 PM
Synthesis of four Gigabyte P35-DS3R reviews Babrbarossa Reviews & Articles from the Web 4 June 4, 2007 10:18 AM
