Old February 9, 2008, 09:57 PM
biff's Avatar
Interesting. My PC at work has a p35-ds3r that I'm probably going to swap with my 935p-ds3 at home. On the ds3r the NB is fairly cool to the touch but the SB is hot enough to be very uncomfortable to the touch and this is only @ 333MHz FSB. Seems to be completely opposite of what most report.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
Old February 10, 2008, 06:46 AM
Mr. Cipher's Avatar
I realized that with my 8800gtx, I don't think I will be able to fit a sb heatsink on...
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | BFG GTX 295 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Intel E1xxx & E2xxx OC Thread
Old February 10, 2008, 09:19 AM
3.0charlie's Avatar
HR-05 SLI should work.
Old February 25, 2008, 01:09 PM
Mr. Cipher's Avatar
Just ordered the HR-05 SLI for $30...pricematched DC with NCIX. Then the $10 shipping brings it back up to NCIX's retail price, so we have $18+$10+tax = $30. Not bad I don't think.
Finally my SB will have some cooling. Can't believe I haven't damaged anything yet with my OC and unprotected SB. Thanks for your help everyone.
**EDIT: Just double checked the compatibility list and...the HR-05 SLI is not compatible with my DS3R southbridge. Looks like the bugger is going to be naked for a little while longer yet. **
**EDIT 2: After looking around, I realized that my NB needs some cooling too and the stock Giga HS for it isn't doing a good job, the HS is really, really warm to the touch. I think I will have to resign to a low profile SB HS if I can't find out about the HR-05 SLI compatibility, but at least I can get an HR-05 IFX for my NB. **
i7 Red
C2Q Blue
Old February 25, 2008, 05:11 PM
Prof. Dr. Silver's Avatar
You might just want to get two little 40 mm fans($ 5) that you attach to the standard heatsinks....did that on my DS3L and it brought temps down to the low 40s!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old February 25, 2008, 05:58 PM
3.0charlie's Avatar
I don't understand why the compatibility page (HR-05 / IFX Series & HR-09 Series Compatibility List) shows that the HR-05 works, while the HR-05 SLI won't. Doesn't make any sense.
Old February 25, 2008, 06:17 PM
biff's Avatar
Where are you getting those temps readings from?
Asus P5Q-PRO
EVGA GTX 280 (SC?)
Old February 26, 2008, 05:20 AM
Mr. Cipher's Avatar
Emailed TR about the HR-05 SLI's compatibility with my SB. Hopefully I will get a response soon and will let you know what they say.
I would bite the bullet and order it in advance, except I am unsure whether or not I can return it to NCIX.
If it is not compatible, I will have to get the the enzotech SLF-1 low profile copper HS for my SB, since nothing else will fit under my GTX. What an adventure this has been. Maybe this will let me OC more...
i7 Red
C2Q Blue
  #19 (permalink)
Old February 28, 2008, 11:03 AM
Mr. Cipher's Avatar
So after the email I got back from TR, I didn't feel confident getting the SLI for my SB.
I thought "ok, I will get the Enzo SLF-1". Arrived today and...does not fit on my motherboard. the bracket on the HS hits some capacitors and the jumper for clearing the bios. Fantastic!
Plus, I have been getting the run around from both Gigabyte and the retailer where I bought my board, regarding getting a GA HS for my board.
What a day. Any suggestions?
i7 Red
C2Q Blue
  #20 (permalink)
Old February 28, 2008, 11:42 AM
Cptn Vortex's Avatar
Can you describe which parts of the heatsink are not lining up for the Thermalright? It may not be perfect, but I think you should be able to jimmy fit the pegs in there...
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Ram for a GA-P35-DS3R sircuster RAM 12 April 7, 2008 10:35 AM
GA-P35-DS3R - no bios/boot Mr. Cipher Troubleshooting 5 March 13, 2008 07:25 AM
Gigabyte P35C-DS3R tom.mullie CPU's and Motherboards 7 January 21, 2008 08:06 PM
Reviewer Tryouts: GA-P35-DS3R Mr. Cipher Member Reviews 10 November 20, 2007 07:20 PM
Synthesis of four Gigabyte P35-DS3R reviews Babrbarossa Reviews & Articles from the Web 4 June 4, 2007 10:18 AM
