Corsair A70 CPU Cooler Question Which Memory modules are compatible with the Corsair A70 with Push/Pull setup ? |
It more depends on your case and motherboard your using than anything else. The Corsair H70 works with most types of memory.l |
I'm planning on getting the Corsair 650D case. And as for the motherboard I'm thinking of the ASUS P8P67 B3 board. I really what to know if the G.SKILL RipJaws X Ram will work with the Corsair A70 cooler in a push/pull setup. |
| All times are GMT -7. The time now is 11:08 AM. |
