<~----> coolermaster hyper 212+ on Asus p8h67-m LE motherboard - Hardware Canucks
Old April 26, 2011, 03:05 PM
Default coolermaster hyper 212+ on Asus p8h67-m LE motherboard
I've read that the CM hyper 212+ is known for its size and that it sometimes covers up memory slots. I'm wondering if it will fit on my P8H67-M LE motherboard without covering up DIMM slots. I've got Gskill Ripjaws memory installed --> Newegg.ca - G.SKILL Ripjaws Series 4GB &#40;2 x 2GB&#41; 240-Pin DDR3 SDRAM DDR3 1600 &#40;PC3 12800&#41; Desktop Memory Model F3-12800CL9D-4GBRL.
This mobo only has 2 memory slots, so covering up one would mean i'm screwed .
Any idea if it'll fit?
Old April 26, 2011, 04:51 PM
even with your only 2 slots, in theory you should be fine, but you wont know unless someone with the same setup gives you a more concrete answer :)
i keep regular/cheap ram around just for cases like this.
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 64 May 7, 2011 09:33 PM
i7-930 temps w/Hyper 212 Plus. God of Sprite CPU's and Motherboards 11 March 1, 2011 07:45 PM
CoolerMaster Hyper 212+ nikokapo Air Cooling 4 September 8, 2010 06:30 AM
CoolerMaster Hyper 212+ performance on i7 marstedt Air Cooling 8 May 30, 2010 12:15 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 03:56 PM
