Old May 15, 2011, 08:01 PM
Originally Posted by ZZLEE View Post
I wish I knew I could order something like this when I ordered my extension and SATA cables! Thanks. The shipping is kinda high for that but I will try to figure something out.
Old May 15, 2011, 08:49 PM
if u have 4/8 zip-ties lying around, you could zip-tie both fans together passing between the fins for a cleaner look. used to do that on the xigmatek hdt-s1283 which only supported one fan natively...
Old May 16, 2011, 04:28 PM
I think I have to take the mobo/heat sink out of the case, though. The extension cable doesn't hold together and then the 8-pin becomes a dual 4-pin! UGH! I am trying to line up to the connector but the corner of the heat sink is obstructing my path a bit.
I am inquiring about upgrading to a cheap Sandybridge system, too.
I thought min. i3-2100T is as good, generally, as the Q6600 but a dual core. It's faster in most applications especially those only needing two cores.
I need to find out if I should get a decent mobo and then the cheap i3 cpu so I can buy another high end cpu later if I really want to. Or?????
At any rate, I am considering removing the mobo/heat sink out of the case and then I can re-do the fan attachment.... I could even take pictures and put 'em in an ad! LOL!
If only I could buy A SECOND SYSTEM! WOULD BE SO MUCH EASIER!
Old May 16, 2011, 04:55 PM
ZZLEE's Avatar
Newegg.ca - Athena Power 12" EPS-12V (8Pin) connector Extension Cable Model Cable-AD10 - Cables
8 pin extenshion ?
edit: NCIX.com - Buy Works 8 Pin EPS Male to 8 Pin EPS Female Extension Cable 12IN - Works - CB-8M-8F - in Canada
egit 2 : GELID PWM Y Cable Splitter Adapter Share 12V Case Fan on eBay.ca (item 160357585105 end time 13-Jun-11 22:07:02 EDT)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 17, 2011, 06:34 AM
That 4 pin adapter looks interesting, thanks! I think I might go with it. Unfortunately, NCIX doesn't carry that one (anymore?) so I need to use ebay... ugh... that particular one is coming from HK(?) so more than a 3-wk wait! I might have to go with an American seller so hopefully cut down on that...
Thanks for the tip.
The extension cables I have already. I took so long because I was hesitant to invest in more parts for this old system ...wondering if I should upgrade... but, I guess if I look at it as not major investments...a few dollars here and there on cables! Just don't want it adding up.
CPU Heatsink help Smoogler Air Cooling 13 September 10, 2010 04:40 PM
i7 920 - Which heatsink? hen555 New Builds 5 May 16, 2010 02:17 PM
The best Heatsink rapmaster Air Cooling 19 February 26, 2010 03:38 PM
New Heatsink miggs78 Air Cooling 13 June 10, 2008 07:32 PM
Heatsink problem miggs78 Air Cooling 11 April 10, 2008 11:49 AM
