Old April 14, 2011, 10:07 PM
Default 200MM fans inquiry
Hey guys,
i m wondering is there 200MM that can runs at about 2000RPM or even 1500?
The two coolermaster 200MM fans i have is running so slow.. at about 700RPM only
I dont feel enough airflow.. lol
Please help..
Old April 14, 2011, 10:44 PM
most of the consumer ones are like that, take tt's ones(200-230mm) they run under or around 1k rpms.
having blades that big warrant little spinning to generate considerable air movement.
pressure,well,not quite there :)
Thermaltakeusa**DC Fan**200mm Fans**200mm Blue LED Silent Fan : 200mm Blue LED Silent Fan AF0046
Thermaltakeusa**DC Fan**230mm Fans**230mm Blue LED Silent Fan : 230mm Blue LED Silent Fan AF0047
and yeah im a sucker for those huge fans. i build two sideless rigs with them lol.
they look weid,but hey
PC CANADA - THERMALTAKE 23CM BLUE LED FAN [AF0047] - The Original and Highly Rated All-Canadian WebStore
Old April 15, 2011, 01:32 AM
If these are the ones you ( laplapmax) are talking about MegaFlow 200 Blue LED Silent Fan - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply then I don't see why there is a problem; I had one of these on my old air-cooled rig, it seemed to work very well-doesn't take a lot of speed to produce a lot of CFM.
As for static pressure; is not the higher the number the better (e.g. Thermaltake AF0046 @ 0.175 mmH2O vs Cooler Master @ 0.595 mm H2O ), so the Cooler Master would have the higher static pressure?
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old April 15, 2011, 02:35 AM
or this maybe?
Newegg.ca - Rexus Rexflo250mm 250mm Case Fan
any bigger and youll probably be looking at industrial or radiator fans
Old April 15, 2011, 05:41 AM
Soultribunal's Avatar
Unfortunately it won't feel like a lot of airflow becuse it is over a larger area.
If you take a 10CFM 4000RPM 40mm Fan and put it up against a 120mm that does 20CFM at 1300RPM it will feel like the 40mm is pushing more air.
Same is true for these, the Big Boy 200mm pushes out a monsterous 100+CFM. There is massive airflow in that fan, so don't panic that you don't 'feel' like there is a lot of air movement...there is.
AS for static pressure, its on a 200mm+ fan, static pressure is a non issue unless you are mounting it to a RAd or HSF, which is highly unlikely.
ST
www.realhardwarereviews.com
Upgrading a 200mm fan mattydies Air Cooling 0 September 19, 2010 10:38 PM
Which 200MM fans work with the Antec 900? cul8erppl Air Cooling 0 May 31, 2010 10:40 AM
US Feds deciding who should start Apple antitrust 'inquiry' chrisk iPhone & iPods 11 May 7, 2010 05:04 AM
Left 4 Dead 2 4-Pack inquiry Arinoth Gaming 0 February 28, 2010 07:23 PM
[WTB] Looking for 200MM CM Sniper Fan xXxRithxXx Buy/Sell & Trade 10 April 15, 2009 08:14 PM
