I want to switch the fans in this,
Super Micro Computer, Inc. - Products | Accessories | Mobile Rack | CSE-M35T-1
For these since there faster and move more air,
Newegg.ca - VANTEC TD9238H 92mm Case Fan
Now my question is, do you think they would work? It looks like the normal 3 pin fan connector on the enclosure so in theory it should work right? Also do you think I would be voiding the warranty by replacing the fan? Here is the pinout of what the 3 pin looks like on the enclosure as well,
So what do you think? Is this worth the swap would you think? I've read a couple reviews that say the stock fans don't keep the drives that cool and make alot of noise. I have also emailed super micro about this but it says it can take up to a week for a reply :(
Also think it would work as this fan gets power from the 4 pin molex but has a 3 pin for the RPM sensor. So I was wondering if the enclosures fan failure might go off cause it's not drawing power from the unit but only using the RPM sensor?
