<~----> Thermal Tape - Hardware Canucks
Old March 9, 2011, 04:22 PM
bvsbutthd101's Avatar
Default Thermal Tape
Wasn't really sure where to post this
But I was wondering whats the best place to buy thermal tape from. I just bought a arctic accelero xtreme plus and I don't want to use the liquid adhesive that comes with it.
Old March 9, 2011, 04:28 PM
JD JD is offline
Dazmode has quite a few choices: THERMAL SOLUTIONS : DazMode, Canadian PC Water Cooling and Modding Store
Not really sure what to suggest as I'm not sure what you're using it on. Depending on the gap you may need a thicker pad or if it's a flat surface then the 3M 8815 will probably do.
However it's usually best to use thermal paste on the core/GPU/CPU. Arctic Cooling's MX2/3/4 compounds are all non-conductive so there isn't any need to worry. I'm sure the paste they provided is non-conductive as well.
Old March 9, 2011, 04:35 PM
im using ID DIAMOND thermal compound on the actual gpu itself but i need to attach these heatsinks to the vram
Arctic Cooling ArcticVR004 Arctic Cooling VR004 VGA Heat Sink For NVIDIA GTX480 from mwave.com
Old March 9, 2011, 04:56 PM
botat29's Avatar
thermal tape do not hold very much, if you don't plan to remove the heat sink latter you can use the epoxy thermal paste, it's 2 tubes you mix them and it hold permanently the heat sink, I always use them as the last thing I want it's a memory burn because the heat sink fall.
But be advice that’s a permanent solution, you can’t reverse it.
NCIX.com - Buy Arctic Silver Alumina Thermal Adhesive 2 X 2.5 Grams - ARCTIC SILVER - AATA-5G - in Canada
Old March 9, 2011, 05:54 PM
that's one reason i don't want to use the adhesive. Just in case my card goes bad want to be able to put the stock heatsink back on and RMA it.
Old March 9, 2011, 08:36 PM
JD JD is offline
Well in that case the thinest stuff should be fine. However make sure you thoroughly scrub the DRAM chips with 99% isopropyl alcohol to ensure it sticks on decently.
Old March 9, 2011, 09:07 PM
I got mine off ebay from here.
Heatware
Old March 10, 2011, 04:03 AM
I just bought some ArctiClean, I think that will clean it up good.
Alright thanks for the input guys. The cooler comes in Tuesday so I'll lets yous know how it goes when I'm finished installing it.
Old March 10, 2011, 04:12 AM
Supergrover's Avatar
I have used TIM, MX2/as5 and then use a tiny, as in a pindrop of crazyglue in one corner, to remove the sinks pop it in a antistatic bag and place it in the freezer for 5-10 minutes, then sinply twist the heatsink off. Been doing it this way for 5-6 year works without a flaw everytime.
If you are not happy with the Thermal tape I have a crapload of 3M, simply PM and I can send you out a couple of feet worth via snailmail.
R.I.P.
Old March 10, 2011, 08:06 AM
what's 3M
[WTB] Double sided Thermal Tape! tragd Buy/Sell & Trade 3 July 5, 2010 05:14 AM
Thermal tape for GPU mem Eldonko Video Cards 54 May 14, 2010 01:54 PM
Thermal tape and other solutions... Mavvens Air Cooling 7 February 21, 2010 06:33 AM
Voltage regulator block (Thermal tape or thermal counpound?) Mavvens Water Cooling 5 August 8, 2009 06:56 PM
[WTB] Thermal Tape punk_zappa Buy/Sell & Trade 0 June 28, 2009 02:15 AM
