Old March 3, 2011, 11:45 PM
CTA's Avatar
CTA CTA is offline
Default new IC? Perihelion?
some of you know about ic diamond... recently IC releases new thier product for budget called perihelion...
oddly... why nobody tells us? :\
Perihelion
Innovation Cooling Perihelion Thermal Compound Review Overclockers Tech [image is dead :\]
IC Perihelion Review - Overclocking, News, Reviews, and much more
Official IC Perihelion Test Results Thread - Overclockers Forums
it seems a great paste for budget...
Old April 4, 2011, 02:44 AM
It seems that IC's new product doesn't cool much better than any other (ceramic-based) thermal compound; I'm currently using their IC 7 thermal compound (depending on the current room temp.), the temps hover between 23 and 29 deg Celsius.
" If I had a dollar for every time I heard "My God! He's covered in some sort of goo, " I'd be a rich man. "
Homer J. Simpson
Old April 4, 2011, 06:49 PM
There may be something in the works. Checky da linky...
Innovation Cooling 7 Carat Diamond TIM Test results thread *NOW ACCEPTING RESULTS!!*
Old April 4, 2011, 08:21 PM
MacJunky's Avatar
As far as I can recall I *think* I am still running on my last application of ICD7..
