Old March 3, 2011, 11:33 PM
Default Corsair A50 or CM Hyper 212 Plus
Both these coolers are on sale at NCIX right now. Which would offer the best performance? The 212+ is $5 more than the A50.
Old March 4, 2011, 12:17 AM
going by this the a50 is better.
Old March 4, 2011, 05:06 AM
Rison's Avatar
Stock, the A50 is better. but you can mount 2x 120mm fans on the CM 212+, which will outperform the A50's one 120mm easily.
I'd take the CM 212+ hands down over the A50 any day.
I'll learn to manage my anger, when people learn to manage their stupid.
Old March 4, 2011, 07:33 PM
rjbarker's Avatar
PM'd the 212+ to $23....that is a friggin cheap AHSF assembly, results with a single Fan are reasonable as well...
Firestrike Extreme: 21.452
MARK 11: 32.530
Old March 4, 2011, 07:53 PM
headsh0t's Avatar
Wouldnt it include clips for a second fan? I'm pretty sure they have a variation that comes stock with 2 fans. Also with the A50 being $10 cheaper than the CM212+ right now in the NCIX sale I would take that. In fact that's what i was going to do a week or two ago but the A50 sold out in the NCIX sale so I couldn't PM at Mem Express and got the CM212+ instead.
edit- Nevermind, checked it out the A70 is the one with dual fans, A50 doesn't come with extra fan mount, and the CM212 is on sale for $20 so it's only $5 more. I'd probably get the CM212, but if you just wanna roll with one fan then A50 would still work fine
Old March 4, 2011, 10:00 PM
spikexp's Avatar
The A70 was on sale for 25$ last week...
The best performance would be the hyper 212+ with push pull setup (require to get another fan).
Old March 5, 2011, 06:18 PM
I just bought the a50 this week. I haven't installed it yet but the fan is pretty loud to me even when using the resistor. I tried it with fan controller + resistor and it was more acceptable. It sucks that the fan isn't pwm but oh well for 15 dollars you can't really lose.
Old March 6, 2011, 11:57 AM
So I decided to pick up the 212+ since you can use a push/pull setup with it. so far temps are better than stock but aren't super amazing. I got my i5-2500K to 4.2Ghz with 1.25v and it idles around 40s and goes up to 55-60 on load with Prime95. I guess the high idle temps is because of my case(Lian-Li A05BN). Another issue is the fan seems to make this light scrapping noise. It isn't a a big issue since the sidepanel is always. I'll probably drop the cash for some Noctua fans down the road.
Thanks for everyone that helped.
Old March 12, 2011, 12:01 AM
Hitikiro's Avatar
Definitely consider some Noctua fans. I got a Push/Pull set up (NF-S12B) with the TRUE 120 and it dropped my both idle and load temps by 4 degrees Celsius.
Intel Q9550 @ 3.95ghz (1.32v) | Abit IP35 Pro "Snake" | 4 GB Kingston HyperX T1 PC2-8500 | Thermalright Ultra 120 Extreme w/2 X NF-S12B | MSI 465GTX GE (unlocked to 470GTX) | Corsair HX520 PSU | Boot Drive: OCZ Vertex 2 60GB SSD | Storage: Seagate 500GB HDD | Antec P182 Case | 3 Yate Loon DS12L (undervolted) | 2 x Pioneer DVR-212D | Samsung 226BW
i7-930 temps w/Hyper 212 Plus. God of Sprite CPU's and Motherboards 11 March 1, 2011 08:45 PM
Amd 1055T and CM hyper 212+ cosworth88 Air Cooling 13 February 11, 2011 07:58 PM
I5 750 with Hyper 212 Overclocking Help Please Dot Merix Overclocking, Tweaking and Benchmarking 32 September 17, 2010 09:45 AM
CoolerMaster Hyper 212+ nikokapo Air Cooling 4 September 8, 2010 06:30 AM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 04:56 PM
