Old February 28, 2011, 05:45 AM
Trial Member
Default Cooler for i5 750 LGA1366
Hey guys,
im a complete scrub when it comes to cpu coolers, and ive been reading some reviews but thought
to get some advice from some experts.
What would u suggest that's not that loud( the comp is in my room and i usually leave it on at night for downloads)
thanks
Old February 28, 2011, 06:43 AM
lcdguy's Avatar
if it will fit i personally use the GELID Tranquilo on my i7 950 and on my bro's i5. They are also relatively quiet.
Old February 28, 2011, 06:54 AM
Arinoth's Avatar
Just to let the OP know, the i5 750 is NOT LGA1366, it is actually LGA1156 which will make a difference as not all coolers come with the default plate for both, as well as the i5 750 will NOT fit in a 1366 motherboard.
Here I am: here I remain
Old February 28, 2011, 09:46 AM
lcdguy's Avatar
Except the one i hinted at ->NCIX.com - Buy GELID Solutions Tranquillo LGA775/1156/1366 AM2/AM3 I7/I5/PHENOM Heatpipe Cooler PWM 120MM Fan - Gelid Solutions Ltd. - CC-TranQ-01-A - in Canada.
supports 775/1156/1366
Old February 28, 2011, 03:17 PM
SneakySnake's Avatar
Do you overclock? If not then the stock cooler will be fine, but if your looking for a good aftermarket one then the Cooler Master 212+ is a favorite of many guys on the site.
Like It was said earlier. The i5 750 isn't a LGA 1366 socket CPU, so while your correct that it usually doesn't matter for the CPU cooler, as they are pretty cross platform, it does matter significantly for a lot of your components.
i5 750 stock cooler irtehleet Overclocking, Tweaking and Benchmarking 7 May 3, 2010 10:21 AM
Need help to choose LGA1366 mobo ADay2Long New Builds 16 January 16, 2010 06:41 PM
GTZ LGA1366 Adapter SugarJ Water Cooling 7 February 13, 2009 08:47 AM
dearth of lga1366 waterblocks Babrbarossa CPU's and Motherboards 45 December 22, 2008 07:59 AM
