Old January 17, 2008, 12:30 AM
donimo's Avatar
Default Thermalright Ultra 120 Extreme, 2x Noctua P12's and A/C MX-2 gets you this!
With my Arctic Cooling Freezer 7 Pro (no slouch itself) and an e6750 o/c'd to 3.2GHz I got this with CoreTemp:
Idle: 38C
Load: 59C
dB: Vrooom!
With my brand new TRUE with two Noctua NF-SP12's in a push/pull config and Arctic Coolings new MX-2 thermal compound (all bought due to reviews from this site, you guys should ask for a cut from NCIX) I get this:
Idle: 18C
Load: 36C
dB: Quieter than my YL case fan's so I cant hear it.
Now those are double take numbers people
That is water cooling numbers for an easy 90 bux after tax
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 17, 2008, 12:50 AM
wow! how cold is your ambient (room) temp? are you sitting outside or something???
Nothing's out there. All there is is sea, and birds, and fish. And 20,000 tonnes of crude oil. And a fire. And the part of the ship that the front fell off. But there's nothing else out there - it's a complete void. The environment's perfectly safe.
Old January 17, 2008, 11:27 AM
donimo's Avatar
I havent measured it, the thermo is set at 23C, but this PC is downstairs, so I would say maybe 15-18C, especially seeing as the CPU cant go below ambient...
Still, I sit down there for hours in shorts and a t-shirt so it cant be much lower than 15C
Old January 17, 2008, 12:39 PM
Thund3rball's Avatar
Suhweet!
"this is not troll. this is real deal!" - hohohee
Desktop:
See the drop down!
Laptop: Dell XPS M1530 \\ T7500 2.2GHz \\ 3GB 667 \\ 6 Cell \\ 8600M GT \\ 200GB 7.2K \\ WSXGA+ \\ Bluetooth/Wireless \\ MS Blue Track Mini \\ Vista Ult. (RED)
HEATWARE
Old January 17, 2008, 01:10 PM
Where can I find some MX-2 !!
Back up - Ebay (Inik1) or Heatware
Old January 17, 2008, 01:25 PM
magictorch's Avatar
Default MX-2
Yes, where can you find the MX-2...I need some
Time to push your E6750 a bit more don't you think? Just stick it to 3.6@1.35v and run the stability tests tonight.
You might be looking at close to 4ghz later on with those sort of temps
Old January 17, 2008, 01:28 PM
werty316's Avatar
What is the tjunction value that is being read in CoreTemp? If it says 85C its wrongs as the tjunction for the E6750 is 100C so you need to add 15C to your temps.
However if those temps are indeed correct, they are quite nice I must say. I am surprised you aren't just a bit chilled when you are wearing shorts and a t-shirt in your basement.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old January 17, 2008, 01:32 PM
i got some MX-2 from NXSource. around $5 for the smaller tube. hey, $2 cheaper than AS5!
Old January 17, 2008, 01:40 PM
donimo's Avatar
It's 100 Tj in core temp.
funny side not is that my e2180 when I moved it upstairs now states it is Tj 85 when it was 100 downstairs, same board....
I am a bit chilly, I wear fuzzy socks though...
I am going for 3.4 on stock Vcore today after work, 3.6 is after that, 4.0 would rule but I am not holding my breath...
Old January 17, 2008, 01:46 PM
werty316's Avatar
You have plenty of headroom considering the temps you are getting so you should be able to get to 3.6GHz without any issues and 4.0GHz is probably do-able too.
You got a kickass HSF so why not take advantage of it.
Antec 900 and a Thermalright Ultra 120 CasheKicker Air Cooling 22 March 30, 2008 05:02 PM
Reviewer Tryouts: Thermalright Ultra-120 Extreme gof Member Reviews 7 November 23, 2007 11:17 PM
Where oh where to get a TR-120 Ultra Extreme? Dus Water Cooling 5 September 27, 2007 08:19 PM
Thermalright Ultra120 Extreme DOES NOT FIT in STACKER 832 CMetaphor Air Cooling 10 May 20, 2007 10:24 AM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
