Old January 17, 2008, 12:53 PM
donimo's Avatar
I have VERY recent experience that was similar to this with crap results (last week).
My e2180 went from 2.0 to 2.7 on stock volts, but took 1.48 volts Vcore to get to 3.0, and it wasnt even orthos stble there.
So just because it goes up 20% easily doesnt mean it'll do 21% at all...
but yeah, I am reaching for as high as I can go here...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 17, 2008, 01:16 PM
magictorch's Avatar
Default looks like a nice E6750 though
Yea I guess once you hit the wall thats it really. It seems that "top" stock (1.35) gives you a pretty good idea of where the chip will get to..after that.........
Anyway I think 3.6 at 1.35 is do-able, thats where I am right now although Im close to 60oc after running Orthos so Ive never gone higher.
Your cooling is better than mine (scythe with 1 fan) so you should get higher. There are quite a few reports of these chips breaking through 3.8 now without too much effort....especially on P5KE boards
Old January 17, 2008, 01:24 PM
donimo's Avatar
here's to hoping!
Check out that sexy all copper ninja on the NCIX sale page, the fixed the heatpipe spacing on it as well, geekpr0n
Old January 17, 2008, 01:47 PM
magictorch's Avatar
Default yea the sythe ultra copper looks nice
Yes i saw that earlier and was wondering how much better it performs. I hope they have a backplate for it as i dont like the push pins when using the heavier NF-P12 fans.
Ive got another NF-P12 coming and I think the heat-sink will just fall out the board!
Old January 18, 2008, 04:32 PM
Cptn Vortex's Avatar
Geeze that ninja is over 1kg.....your board would not forgive you......
The Vortex H20
MSI Z77A-GD65
Intel i7 3770K @ 4.6GHZ 1.28v
Galaxy GTX 680 @ 1241MHZ
8GB Mushkin Blackline 1600MHZ 9-9-9-24 1.5v
Asus Xonar Essence STX
OCZ Z-Series GOLD 850W
2 x 128GB Corsair Force GT SATA3 SSD RAID0 :)
Acheiva Shimian Q270 Lite 2560x1440
Benq W500 Pojector.
Watercooling:
EK Supreme HF, EK FC GTX 680 Block, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, EK Coolstream XT 220 RAD Gelid Wings Push/Pull.
Old January 18, 2008, 04:43 PM
donimo's Avatar
I am sure my TRUE and 2 fan combo is over a kg
Old January 18, 2008, 07:17 PM
Hehe, nice. SKYMTL, Scythe send you some stuff yet? Perhaps a review of the Ninja Copper coming? WOo!
The Vortex H20
MSI Z77A-GD65
Benq W500 Pojector.
Watercooling:
Old January 18, 2008, 08:01 PM
Juste received my Ultima-90 :D
Time to oc this little Q6600 with a NF-P12
Back up - Ebay (Inik1) or Heatware
  #19 (permalink)
Old January 22, 2008, 08:11 PM
Droc's Avatar
E6400 stock clocked.
With the stock intel cooler, she ran at 39C idle
With the TRUE and a single YL Im down to 28C
Room temp is 22C and until I get my new case stand, my P180 is 4 inches from the baseboard heater. So 6C over ambient being extremely close to a heat source, Im pleased.
After a few days the thermal compound should settle and a consistent temp should be obtainable.
Asus P5N32-E SLI Plus : Intel E6400 : 2GB OCZ 6400 DDR2 : BFG 8800GTS 320MB Factory OC : Antec P180 : Samsung 226BW
  #20 (permalink)
Old February 9, 2008, 05:19 AM
hmm i was thinking of getting ultra 120 with noctuas for the e8400. but i noticed noctua has the NH-U12P. saves me a bit of cash, would there be much performance difference ?
E8400
G-B P35-DS3
Corsair 2G Kit 667
G-B 8800GT 512MB OC (+Accelero S1)
Seagate 7200 320G SATA 16MB cache
Seasonic S12+ 550W
Antec P182
Logitech Z-2300 Speakers :)
Antec 900 and a Thermalright Ultra 120 CasheKicker Air Cooling 22 March 30, 2008 05:02 PM
Reviewer Tryouts: Thermalright Ultra-120 Extreme gof Member Reviews 7 November 23, 2007 10:17 PM
Where oh where to get a TR-120 Ultra Extreme? Dus Water Cooling 5 September 27, 2007 08:19 PM
Thermalright Ultra120 Extreme DOES NOT FIT in STACKER 832 CMetaphor Air Cooling 10 May 20, 2007 10:24 AM
A second look at the Thermalright Ultra 120 eXtreme Babrbarossa Reviews & Articles from the Web 2 May 4, 2007 06:23 PM
