Originally Posted by Modus I recently made the move to a i5-2500K setup from a E8400. I decided to lose the H50 and go for a high-end air cooler. however some things came up and now I cannot afford one. I have an old Xigmatek S1283 cooler with the thermal-right LGA775 bolt-thru kit. Does anyone know if this bolt-thru kit is compatible or if not, is there a LGA1155 bolt-thru kit I can use? |
yes i believe it is, i have a same cooler/bolt through, and i will be buying a 1156 (pretty close) and checked this out, but to be safe double check the bolt through kit you bought with the xigmatech website, i think there are only 3 kits available...so...well..33% chance atleast you are okay..lol
