-   Air Cooling (http://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Cooler for i5 2500k - 1155 (http://www.hardwarecanucks.com/forum/air-cooling/41077-cooler-i5-2500k-1155-a.html)
JPHarry February 24, 2011 04:01 PM
Building a new high spec gaming PC and will be getting the new i5 2500k processor. Will I need to replace the stock CPU fan? And if so, any suggestions that fit the 1155 socket? Thanks,
maverick_brent February 24, 2011 04:08 PM
Xigmatech s1283 and bolt through kit
_dangtx_ February 24, 2011 04:39 PM
hr-02 for fanless? :)
Arinoth February 24, 2011 04:47 PM
I have a CM Hyper 212+ installed in a push/pull configration (R4 fans) that seems to keep the processor cool. I'd highly recommend it for its price point.
frontier204 February 24, 2011 06:24 PM
What's your budget and goal? (overclock? quiet PC?)
You can refer to this thread for some ideas: http://www.hardwarecanucks.com/forum...tml#post472819
I have a Prolimatech Megahalems (1 fan) and I find it overkill for my 2500K overclocked to 4.2 GHz. At full load (F@H SMP) my CPU doesn't go past 50 degrees Celsius even when I turn off my case's top exhaust fans.
If you look at some reviews, you'll see that you can overclock a 2500K even with the stock cooler, but it will be one of the louder fans in your case if you do so.
Eluder February 24, 2011 06:55 PM
I was using a CM Hyper 212+ on my i7-2600k, but right now I'm on stock as one of the bolts to secure the backplate just won't thread properly anymore (moved from CM 690 case to CM HAF 922).
It did a great job of keeping my CPU really cool at ~55 on load at 4GHz when it was in the 690, wasn't using the stock fan and it was nearly silent with the replacements. I look forward to seeing how it'll do when I can get it installed in the HAF 922.
Reyzac February 25, 2011 09:02 AM
Hyper 212 hands down.
Unless your budget is high, then maybe a V6GT, Prolimatech Armaggedon, etc.
JPHarry February 25, 2011 12:37 PM
Conisdering the huge popularity I'm going to go with the CM 212+ (good quality at a very affordable price) Thanks for your input everyone :biggrin:
SneakySnake February 25, 2011 02:18 PM
Yea I'll toss in another thumbs up for the CM 212+.
I'm using a V6GT on mine, and it's kinda overkill. I went to the store to get a 212+, but they were outta stock, and I wanted a cooler immediately lol
