Old February 23, 2011, 12:21 PM
coleo's Avatar
Originally Posted by Rison View Post
I've seen the slot cards that either just blow internal air at a GPU, or bring it in from the back (back is usually a bad idea).
I find the fans are too "short" and aren't anywheres near the fan of the GPU.. so it just blows air at the front of the heatsink and overall doesn't do too much.
You're better off trying to get more air flow in your case. Either by upgrading your system fans (and exaust too, very important for airflow) or, getting a directional duct for an intake fan, and pointing it at your GPU. If you can put a fan on your side panel, that would work too - although I personally don't like them because of having to disconnect the fan when you take the side off.
I don't think its actual air flow that is the problem. the 3 180 mm fans in the bottom of the case move plenty of air. i think the problem is more so changing the direction of the airflow. i seen a flexible spot cooler that i will try
Antec Spot Cool Reviews - XSReviews.co.uk - Trusted Hardware Reviews
Help a noob regarding PSU airflow Houten Power Supplies 14 February 13, 2010 11:04 PM
need some advice TJ07 airflow!HELP!!!!! Cadence Air Cooling 5 November 29, 2008 11:44 AM
my cm690 airflow? CTA Air Cooling 15 September 6, 2008 12:35 AM
New case airflow tubabub New Builds 11 July 2, 2008 08:28 PM
Check your airflow sir????? sswilson Troubleshooting 8 February 25, 2007 10:29 AM
