Old February 22, 2011, 08:48 AM
Rison's Avatar
Originally Posted by enaberif View Post
140mm fans usually have a larger dead spot than a 120mm too which can make a 120mm fan ideal for better environments.
Doh, you beat me to it.
For heat sinks and rads, 120mm is king right now.. due to the dead spot the center winding motor takes up.. and there aren't many 140mm fans available with good static pressure (or, just in general)
As for case fans, 200mm are the "best" right now, as they can move even slower and push more air. Unfortunately the size thing isn't a standard - as each case manufacturer has random widths and screw hole locations for their 200mm fans.
I'll learn to manage my anger, when people learn to manage their stupid.
Old February 22, 2011, 08:53 AM
Soultribunal's Avatar
Yeah I found that one out almost the hard way once. Thankfully I read a few product reviews that actually contained the correct information and helped me from a poor purchase.
Yeah the hub will create a dead spot, but its not really a game changing difference if the radiator itself is enlarged to fit the 140mm anyways. I would imagine the surface area lost/gained by this would be the same.
As for the Static Pressure, yes thats pretty much the failing I see right now is the low RPM numbers are equating to lower H20mm numbers as well.
Time will tell what will happen.
ST
Old February 22, 2011, 01:27 PM
Originally Posted by Eluder View Post
I use Noctua in my system, their NF-P14 FLX. 140mm, but with 120 mm mounting options.
Same here, great Fan
Cheers; Snarl
Another Guy From Canada
[WTB] Noctua NF-P14FLX 140MM Alpine Buy/Sell & Trade 3 January 8, 2011 01:28 PM
[WTB] Noctua NF-P14FLX 140MM (2X) Or any GOOD 140MM FAN Alpine Buy/Sell & Trade 14 September 6, 2010 06:57 PM
[WTB] Lian Li or other 140MM fans lemonlime Buy/Sell & Trade 1 April 30, 2010 01:19 PM
140mm LED fans? FlyingFish Air Cooling 4 March 4, 2010 09:05 AM
What's a good 140mm fan? no_pulse Air Cooling 6 November 25, 2009 06:01 PM
