Old February 19, 2011, 08:13 PM
Your_friendly_gamer's Avatar
Default Titan Fernier X'mas edition for i5-750 p55-ud3
I was just wondering, I recently purchased a titan fernier from a gentleman here and I replaced it with hyper 212+ by cooler master. However, I am not seeing any huge improvement. ALthough, I read big reviews about the fernier.
There is a big difference in size and the size of the heatpipes. One copper heat pipe equals 2 of hyper 212's. Anyways, another thing, the top of my cpu, I scrathed the top surface just a bit while I was trying fit in fernier, is that ok? Or would that make a huge performance difference?
I currently have my set up in Antec 1200, the room temprature is about 20 degrees celicus maybe 22 at most(as its in my basement).
When I overclock my cpu with Titan to 4.0 I reach the temps just under 70 degrees celcius on full load on Prime 95.
On stock 2.66 which has turbo boost so it goes to 3.2ghz, i only get upto 45 degrees with prime 95
PS. Please don't make fun of me too much, but you are more than welcome to do so. As I am in my mid 30's and recently got into PC gaming and wow huge difference from console. I love pc gaming. If you have any suggestions please tell me.
What would be a very good cooler, mind you I dont want to spend more than 60 dollars.
Thanks all!
Old February 19, 2011, 09:12 PM
Thanks all!
first of all, why the frog would we make fun of you,sir?
yes we may be looking like screwing around on here from time to time(talking about myself in particular :D )
but in no way we go out of our way to insult people or anything like that.
now, the 212+ is a killer of a cooler. if you were to test both coolers with the SAME fan?
it would come a bit on the lesser side vs the fenrir. but, unless you apply generous ammounts of voltage+oc? the difference will not be stellar.
now,for the cut. yes it can mess up your temps...1-3 degrees? maybe more maybe less,maybe not
much at least that you wont notice. unless its something like totally bad? shouldnt make much difference, i think.
70c at 4 gigs is a very good tep to have for an i7 hehe, so stop complaining and get those zombies..err..aliens..anyway,whatever you play against!!!
Old February 20, 2011, 11:16 AM
Thanks man, I really appreciate it. I just wasnt sure about the maximum tempratures allowed for an i5. I read on a site for intel that the max is 72.7. I just ran prime 95 again and I got 68 max, but thats fine then. Thanks again for your help Dangtx
Old February 20, 2011, 12:50 PM
Brian@NCIX's Avatar
NCIX System Builder
There is no maximum temp, it differs for all processors, my 970 runs at 90c on a Noctua NH-U12P when overclocked :P
Old February 21, 2011, 10:24 AM
wow 90 degrees eh. I just read the thing from Intel about my CPU and I was just worried a bit. But it never gets over 46 degrees when I am at default and it automatically turbo boosts to 3.2 ghz which is still very fast. So i clocked it back to normal and I only clock it to 4.0 when I am playing a game or something. I wonder why Intel posts these things in the specs:
Intel® Core
I have another question, for the memory, currently I have a 4 gig low voltage ram, if I get 4 more, would that increase any performance? Or its not worth the price?
Thanks again!
Old February 21, 2011, 10:59 AM
martin_metal_88's Avatar
Unless you are doing apps that use over 4GB no. So for everything like gaming, web etc you wont see any increase.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old February 21, 2011, 11:05 AM
Thank you so very much Martin! You are all very helpful and amazing!
[FS] Titan Fenrir X'mas ed - $30 xhrrcollector Buy/Sell & Trade 2 February 11, 2011 08:15 PM
[FS] BNIB Titan Fenrir (x'mas ed) and Intel DHX-B Cooler (i7 970 oem) xhrrcollector Buy/Sell & Trade 14 February 8, 2011 05:00 PM
Need help overclocking my Core i5 750 and Gigabyte P55A-UD3 lsquare Overclocking, Tweaking and Benchmarking 6 April 12, 2010 07:11 AM
[FS] i5 750/Gigabyte P55/8gb Mushkin 1600mhz Fudd Rucker Buy/Sell & Trade 5 January 13, 2010 12:13 PM
[WTB] P55 mobo/i5 750/SSD/GTX275 hausner Buy/Sell & Trade 1 January 11, 2010 06:25 PM
