-   Air Cooling (https://www.hardwarecanucks.com/forum/air-cooling/)
-   -   Review Request: Arctic Cooling 13 Pro (https://www.hardwarecanucks.com/forum/air-cooling/40775-review-request-arctic-cooling-13-pro.html)
CMetaphor February 14, 2011 06:08 AM
I'd love to see a review of this new cooler from Arctic cooling:
Freezer 13 Pro CPU Cooling Arctic Cooling
http://www.arctic.ac/p/images/articl...ec4a36a3_5.png
Pay special attention to the non-shrouded 50mm fan just above the base of the heatsink, supposedly made to increase airflow around the VRM/NB areas.
Also... 300w cooling capacity? Really?
This is a must-see cooler! HWC! Review it please! :biggrin:
_dangtx_ February 14, 2011 11:17 AM
bring it on. that 300 watts must be a mystype right? :)
CMetaphor February 14, 2011 11:22 AM
Maybe, maybe not. 4x 8mm heatpipes is pretty beefy, but it could just be a marketing gimmick.
Still, im more interested in seeing the effect of the open-bladed 50mm fan on the bottom and if it actually does Something. lol
_dangtx_ February 14, 2011 11:48 AM
well, well see..its probably going to be pretty quiet compared to other cooelrs thanks
to those marvelous fans..
but...open bladed what?
CMetaphor February 14, 2011 11:50 AM
Take a look at the high res pictures on the AC site: You can see a small fan (blower-style, but without a shroud) thats attached directly to the base between the heatpipes.
_dangtx_ February 14, 2011 11:51 AM
oh,right! im blind hahah
brilliant idea. even though itll only affect the next inch or so around it its better than nothing.
downdraft coolers? take a step back!
enaberif February 14, 2011 11:54 AM
That little fan looks like it would be powered by the airflow in your case or by thermal induction.. really makes you wonder how fast it would spin.
CMetaphor February 14, 2011 12:34 PM
Nope! Its powered, judging by the RPM figures listed directly on their site: (Its PWM controlled btw)
Rated Fan Speed - 50mm : 700 - 2700 RPM
enaberif February 14, 2011 12:38 PM
Just read the instruction manual on this thing and apparently it uses the same fan header as the cpu.. so the PWM not only controls the main fain but the lower fan..
CMetaphor February 14, 2011 12:40 PM
Originally Posted by enaberif (Post 485640)
PWM requires a 4 pin fan header... only 4 pin I know of on any boards is the CPU fan header.. Unless more boards are coming out with multiple 4 pin fan headers.
Arctic cooling is famous for its "PWM-sharing" tech which allows multiple fans to run off of one 4-pin connector. I'm guessing hats what they're using in this case to control both the 120mm fan And the 50mm at the same time.
