Old February 11, 2011, 12:42 PM
Smoothie's Avatar
The hyper and V8 are so over-rated. Spend the extra money and get a V6, V6GT, Venomous X, Megahalems or a Corsair H50/H70. I have also heard good things about the new Zalman cnps9900 max.
Old February 11, 2011, 01:13 PM
I wouldn't waste money on h70 and 50 or those v6 and v6gt, first hand experience with corsair H series, they are waste of money, my D14 out performed both. for CM V6 people don't seem to recommend them for the price and performance ratio
Old February 11, 2011, 05:45 PM
Originally Posted by LarkStarr View Post
exact same setup
I get to 4.1 ghz on it mostly stable.. I can push 4.2, but keeping that for an extended period is icky. the volts are hiiiigh.
I keep it at 3.8. it's a good sweet spot.
which setup? which cooler are you using?? sorry i haven't understood
the problem is the budget, the hyper costs 23€, noctua and the others cost more than 60€
i have 30\35€ for the heatsink, which is the best buy for my budget?
if the temps will be too higt i'll set the cpu to 3.8
PS 62° is the max temp for the socket (TEMPIN0) or for the cores?
thank you very much for the help!!
Old February 11, 2011, 06:58 PM
cores. so if you get near that it's not good, as i said undershoot it by at least 10deg. you can yes run it close to 62 but that will kill the chip a lot faster.
hyper212+ is popular choice yes but from personal experience it's not ideal for that OC 4 ghz and 3.8 not a big difference.
look at review section and see what fits your bill
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 64 May 7, 2011 09:33 PM
CoolerMaster Hyper 212+ nikokapo Air Cooling 4 September 8, 2010 06:30 AM
Temperatures for AMD X4 940 at stock speed using CM Hyper 212+ cooler p3t3r1 Overclocking, Tweaking and Benchmarking 37 June 30, 2010 08:36 PM
CM Hyper 212 Plus Question prozac26 Air Cooling 9 January 11, 2010 03:56 PM
AMD build help (hyper 212) bumfloss New Builds 6 September 9, 2009 03:34 PM
