Originally Posted by CMetaphor I disagree. Those SS fans are meant for intakes, so they have very little use as an exhaust - directional airflow is useless for exhaust, and the extra airflow shaping used in those fans probably create more disturbance and thus more noise than a traditional silent fan.
Gentle typhoons arent exactly quiet either. IMO theyre meant more for quiet-ish static pressure, and not dead silent exhaust applications. |
At no point in my post did I say that the Directional airflow was ideal for Exhaust.
Just because its directional Airflow doesn't mean it cannot be used, do you have them on your case right now? I'm just curious if you've put them on to know their merits or not.
They are very quiet for the air they move and a very respectable fan.
Quiet enough works for what his application is likely to be, considering he has a pair of 580's inside his case.
Another alternative is the Gelid Wing 12's they are very nice and near silent although they pay for this somewhat in air movement. The PL's move a heck of a lot more air but again there is noise involved with that.
ST
