Old January 20, 2011, 11:54 AM
Default Temp sensor taping
Just picked up a Sentry 2 Fan controller, and the tape that comes with it to hold down the sensors is crap. What do you guys use to hold them down? Even though I really don"t need them as I bought the unit to just control my fans.
Old January 20, 2011, 12:49 PM
stoanee's Avatar
This:
NCIX.com - Buy Arctic Silver Premium Silver Thermal Adhesive 2 X 3.5 Grams - ASTA-7G In Canada.
heatware
Old January 20, 2011, 01:14 PM
Rather go with something that can be removed. On another note, is it a good idea to hook the cpu fans up to the controller or leave it to the motherboard to handle. I have a Noctua NH-D14 whose fans pull 1.8w so the controller should have no issue handling them.
Old January 20, 2011, 01:21 PM
NCIX.com - Buy Thermal Tape 3.5CM X3.5CM ( One Piece ) - Thermal-Tape- X -1 In Canada. Can be PMed much lower, is smaller than advertised.
Or you could just use electrical tape if you aren't concerned with accuracy. I would go with electrical tape.
As for the motherboard headers, check the manufacturer specs. Most good boards handle much higher wattage fans no problem though.
Old January 20, 2011, 01:40 PM
Problem with electrical tape is that when it heats up or gets warm it makes a gooey mess.
Old January 20, 2011, 01:54 PM
Though with the fan controller I can control the speed of the fans for better cooling and the Sentry 2 can handle 8w per channel and the Noctua's only require 1.8w
Old January 20, 2011, 02:13 PM
stoanee's Avatar
It can be removed, use it sparingly and you can pick it off with your finger nail etc.
heatware
Old January 22, 2011, 06:40 PM
TopDogZero's Avatar
I've seen people mix 50% thermal paste in to it, which makes it easy to remove but still allows for a fairly secure bond.
Core temp VS CPU temp cul8erppl Overclocking, Tweaking and Benchmarking 8 January 5, 2011 02:10 PM
Real Temp or Core Temp or Ai Suite Jhayman CPU's and Motherboards 11 November 19, 2009 11:11 AM
Core Temp Sensor issues HalifaxJ Troubleshooting 5 March 16, 2009 12:39 PM
Real Temp or Core Temp ?? FrankyG Overclocking, Tweaking and Benchmarking 11 September 29, 2008 11:24 PM
CPU temp or Core temp? E6420 NOOB Delavan CPU's and Motherboards 18 May 28, 2007 05:07 AM
