Old January 14, 2011, 10:57 AM
Alpine's Avatar
Default Fan filters
IM waiting my new Case and i need to buy some fan filters.
I didn't have any experience with those kind of thing.
What should i check ? (honeycomb etc)
Which kind of material is better than the other ? (plastic, aluminium one etc..) (my case is complete aluminium)
Which one you recommend ??
Thanks for all comments / opinions / helps
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old January 14, 2011, 11:01 AM
ZZLEE's Avatar
Beat direct Buy Silverstone Technology [FF121B] Silverstone FF121B 120MM Fan Filter Black
80/120/140 filters
the 140 are magnetic may not be much help to you :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 14, 2011, 11:14 AM
Alpine's Avatar
Thanks, IM gonna take a look at the 140MM magnetic one. I need 3 140 mm fan filters too.
Old January 15, 2011, 12:15 AM
MpG's Avatar
MpG MpG is offline
If you need good filtering, the Silverstone ones aren't bad, but best filters I've come across are the DEMC ones. Haven't seen them for sale in Canadian locations, but Performance PC's and FrozenCPU both stock a variety of sizes right now. Very fine mesh, and they have a magnetic adhesive ring so you can pretty much stick them anywhere.
Old January 16, 2011, 08:32 AM
Alpine's Avatar
Thank for the info MpG, im gonna take a look at this right now
Automotive Air Filters jcmaz Off Topic 9 December 26, 2010 04:11 AM
Material For Dust Filters? bkh2 Air Cooling 11 January 9, 2010 08:04 PM
fan filters mo' power Air Cooling 1 February 26, 2009 02:56 AM
Where Can I Buy Dust Filters For Case Fans...? mlauzon Air Cooling 11 January 19, 2009 10:49 AM
FS: fan hDD cage w/ 120mm lighted fan, cpu funnel, pentium 1 elninio Buy/Sell & Trade 7 June 20, 2008 12:18 PM
