Old January 18, 2011, 12:35 PM
Originally Posted by Soultribunal View Post
For a mid range overclock it would probably do the trick. However seeing as how you're going to be going up there I would suggest the greater thermal headroom a better CPU Cooler will provide.
For Fans, Coolermaster R4 or Blademaster Fans are top tier when it comes to heatsinks.
Or , get a V6GT as the fans that come on it are premium units.
ST
i was about to pull the trigger on a v6gt earlier in the week (about 55$ if i remember) but i saw posts in forums about it not fitting in an antec 900.
Old January 18, 2011, 12:53 PM
Soultribunal's Avatar
I don't have that case so I could tell you one way or the other.
it is entirelly possible though.
ST
www.realhardwarereviews.com
Old January 18, 2011, 02:46 PM
It won't fit in the Antec 900, it's a 165mm tall heatsink. With the side fan removed the case only has clearance for 162mm IIRC. Standard ATX cases with a 120mm fan typically have clearance for 160mm tall heatsinks, depending on the side fan, which can be removed.
Might want to go for a Scythe Mugen, it can be had for $35 quite often and comes with a single decent fan, just over the Hyper 212 in performance as well.
If you're willing to shell out a bit more cash there's a lot of other choices. Prolimatech Meghalems, Thermalright Venomous-X, and Noctua NH-D14/U12P are the first that come to mind.
Old January 18, 2011, 02:59 PM
Cash isn't that much of a problem. You know more than most just how much those temps have been scaring the pants off me, so investing even 20-30 extra dollars into something that won't disappoint is not out of the question, in fact that's what i'm looking for.
The only other consideration is that there's no way in hell i'm dealing with push pins anymore.
Old January 18, 2011, 09:19 PM
Zalman Max is 152mm Tall!
Zalman Flex is 151mm Tall!! They will both fit!
ST
Old January 18, 2011, 10:15 PM
price matching the mugen 2 at 36.97 at ncix. will get 8$ express shipping.
Need Help picking up RAM Wurmer RAM 1 March 12, 2010 02:31 PM
Need some help picking a case bkh2 New Builds 30 February 7, 2010 06:11 PM
Picking the right Card Heff04 New Builds 6 December 29, 2008 12:11 AM
Help picking a GPU xghostz Video Cards 42 October 14, 2008 06:27 PM
Help picking ISP Dar_ell Off Topic 14 August 11, 2008 04:41 PM
