Old January 9, 2011, 06:51 PM
Delavan's Avatar
Default AKG? Best Coolers for Sandy Bridge 2500K-2600K OC
Hi all,
Sandy bridge is out, we all know that it's based on socket 1155. Coolers compatible with 1156 are also good for 1155. Good news.
Now, as AKG is the Cooling dude, it would be nice if he could tell us what to expect, which coolers would be better suited to run high overclocks on SB's unlocked CPUs 2500K and 2600K... We're talking from 4.6GHz up to 4.8GHz, maybe 5.0GHz (for the lucky bastages that will get a GEM)....
I'm eyeing the Noctua NH-D14, to put on a GA-P67A-UD4 or P8P67 Pro...RQAM clearance will be an issue, but Ripjaws or Muskin Blacks are fine...maybe D14 is overkill for Sandy (NH-D14 cools down hot 1366 chips after all). Sandy, being 32nm, doesn't have the same thermal output as the 1366 CPUs...
So, AKG and all early adopters of 1155 chips, please let's work together to put together an 1155 cooling thread
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old January 9, 2011, 07:20 PM
BigDogg's Avatar
Thermalright Venomous-X CPU Cooler at Memory Express Computers - its on for $49.99
I picked up this to go with my UD7. Not sure about clearance but its a pretty good price. I price matched with NCIX and got $8 express shipping. From what I know they are one of the better HS available.
Old January 9, 2011, 07:38 PM
martin_metal_88's Avatar
Since 1156 cooler fit on 1155 a good 1156 cooler would be as good on the 1155. According to windwithme review of the chip the prolimatech megahalem seems to give awesome result.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old January 9, 2011, 08:11 PM
Bingo I'm just going to stick with the Megahalems.
heatware
Old January 9, 2011, 08:39 PM
gingerbee's Avatar
Megahalems/Thermalright Venomous or even the noctua nh-u12p are top notch coolers loved them all only 1 i still don't have is the prolimatech really didn't need 3 great air coolers
Old January 9, 2011, 08:42 PM
Soultribunal's Avatar
Zalman MAX would be a good fit too, as well as the Flex with the right fans.
ST
Old January 9, 2011, 09:26 PM
Delavan's Avatar
KK, Megahalems ($50 on sale from NCIX, NO FANS included)
Thermalright Venomous X, $75, no fans included...
Noctua NH-U12P ($79, including 2 X p12 fans...)
With two decent fans (push/pull), you reach, or go above the price of the Noctua Nh-14D ($89).
Both the Magahalems and Venomous X are way up there in terms of cooling capability, thx for the advices.
ST
Zalman? They're back in the race? I though they were left in the dust when S775 came out (I may be way out-to-lunch)..
Is it this one?:
NCIX.com - Buy Zalman CNPS9900MAX-R Nickel Plated Copper Headsink Red LED 135mm LGA1156 LGA1366 LGA775 AM3 AM2 - CNPS9900MAX-R In Canada.
You can get a good PMed price on that MAX...really nice
Also, on the Zalman, there is NO issues with RAM clearances, another plus.
From benchmark reviews:
http://benchmarkreviews.com/index.ph...1&limitstart=5
Thanks soultribunal, its a model to consider...
Old January 9, 2011, 10:05 PM
Put 2 of these fan ( can PM with Canada computer for 2$ less ) on the megahalem. End to 50 + 30 so 80 for one of the best performer and some killer fan. I am actually using these fan for RAD and my 212. The Zalman is a nice pick but there is a little stopper for me, if the fan come to die after the warranty then you are screwed.
Ask for more
Martin_metal_88
Old January 10, 2011, 03:15 AM
Delavan's Avatar
Which fans are you suggesting? Where is the link again? lol
For the Zalman fan observation, I agree, I did read that from the reveiw that it's a custom fan, and if it dies, it has to be replaced by the very same thing...good point.
Old January 10, 2011, 05:23 AM
True, but the 3 Zalmans i've had have made it past 2 years now without Fail. And on the old 939 system I donated to my family, the CNPS9000 is still going strong.
Realistically, you will be changing out the whole setup before you worry about replacing the cooler.
ST
Intel Sandy Bridge Core i5-2500K & Core i7-2600K Processors Review Comment Thread SKYMTL CPU's and Motherboards 52 November 6, 2011 08:21 AM
Sandy Bridge 4.5 on AIR i7 2600K ZZLEE Rumor Mill 9 November 26, 2010 10:09 PM
Sandy Bridge tested Bond007 Reviews & Articles from the Web 7 August 28, 2010 11:32 AM
what is intel Sandy Bridge? kuziwk Rumor Mill 18 February 26, 2010 05:40 PM
