Old December 31, 2010, 04:01 PM
botat29's Avatar
Default is the AMD stock cooler on x6 good ?
Hi everyone, first of all Happy New Year,
I receive a 890FXA-GD70 MIS motherboard and a Phenom II X6 1090T Black Edition ( ŗ $ 229 why not) , So I intend to use this board for my 2008 SBS server, I choose this board because it have 2 x ps2 connectors for the keyboard and the mouse, a need for my KVM. And itís a beautiful board too.
The question, do I need to change the stock cooler, honestly all true few computers will be connected to this server , only 2 or may be 3 users at the time, so the server will be very lightly load. I ask because itís the first time I give a shoot to the green team, so I have no experience with their cooler and the heat they produce.
Old December 31, 2010, 04:11 PM
sswilson's Avatar
If you don't intend to overclock it you'll be fine. If you do intend to overclock it, I highly recommend a third party cooler.
Dell Optiplex 3020 / Intel Core i3 i3-4160 / 2 X 4GB DDR3 (Mixed) / Samsung 850 EVO 500GB SSD/ 24" Westinghouse L2410NM
Old December 31, 2010, 04:13 PM
such as cooler master 212+ , v6gt, or thermalright hr-02 on the high end
Old December 31, 2010, 04:15 PM
Infiniti's Avatar
It'll be fine, but they're loud as hell. In the end, I replaced it with a 212+ and it runs a lot cooler and quieter.
Old December 31, 2010, 04:30 PM
botat29's Avatar
Sound is not a problem, it will be in the basement, and as for OC, someone OC a server? .... My question is more about longevity, cold CPU live longer, and dust affects performance too. The problem is; I donít have an aftermarket cooler in hand and I want to install it in the case, and use it now, my case donít have hole in the back of the motherboard, May be I should make one?
Old December 31, 2010, 04:53 PM
sswilson's Avatar
If you won't be overclocking it, and it won't be 100% load 24/7, you should be fine using the stock one.
It does keep temps within spec.
Old December 31, 2010, 05:26 PM
botat29's Avatar
thanks .... I will be busy tomorrow
Old December 31, 2010, 05:35 PM
also, the stock cooler throws air around the motherboard components unlike tall tower coolers. reason for which you may see low end mobos without proper chippie sinks fail when mounted in a poorly ventilated case and the like
How does a AMD stock cooler connect to the motherboard? Blu Air Cooling 8 December 14, 2010 07:21 PM
Temperatures for AMD X4 940 at stock speed using CM Hyper 212+ cooler p3t3r1 Overclocking, Tweaking and Benchmarking 37 June 30, 2010 08:36 PM
Stock CPU cooler? chang2 Air Cooling 6 September 18, 2009 08:15 AM
stock cooler problem v0maru Air Cooling 2 April 13, 2008 03:21 PM
8800 GT gets a new stock cooler Babrbarossa Press Releases & Tech News 6 December 6, 2007 09:42 AM
