Thanks folks. Reviews look good, the V6 needs a good landing pad though. It was too loud 4 me. I went hog wild and bought the CM V10, after the V6GT was returned.
Back gave out so I didn't have a chance to install it yet. I'll be sure to let you know the results.
My Ultra Chilltec had my cpu at 27.5 in idle running 4 ghz. It's been very good but my daughter wants the little man with the shovel in the 5.25 slot, it's a 2 piece unit.
So now I'm looking for a quiet cooler to do the same and thought I'd try a different 1.
At 1.2 kilos, the thing can cool passively if problems arise, though I doubt it would keep up with a high overclock. This thing is a beast!!!
Gotta go hire a crane to install it, hehe.
Cheers!
