Old December 30, 2007, 06:04 PM
Default 80mm fan
i need to find an 80mm fan for my mother's case (old and dusty). I want to see if the cooling the case could be a solution for her comp crashing all the time. Might be some components prob, but 10$ is worth the try. So for you which fan is the best? i was thinking zalman zm-f1 or antec 80mm clear. The noise doesn,t really matter, i need something that can move the air in the old ECS case.
Old December 30, 2007, 07:00 PM
3.0charlie's Avatar
Before buying a fan, you'd better make sure that the fans and heatsinks are clean of dust bunnies. That alone can make a computer crash since the heat transfer does not happen anymore. Clean all heatsinks completly; that should solve the issue.
Old December 30, 2007, 07:07 PM
and how do you clean a very dusty computer?
Old December 30, 2007, 07:15 PM
compressed air and a vacuum if its super dirty.
Old December 30, 2007, 07:23 PM
the inside of the case is grey (dust covered) so Ill go for the vacuum.
Old December 30, 2007, 07:27 PM
BALISTX's Avatar
If you are going to use a vacuum, ensure the system is turned off and unplugged and make sure to ground yourself.
P.S. Don't use the brush the attachment, it could create ESD
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old December 30, 2007, 07:42 PM
3.0charlie's Avatar
And once unplugged, press the Power button once to discharge the capacitors. I use a Q-Tip to dislodge the dust.
Old December 30, 2007, 07:43 PM
MpG's Avatar
MpG MpG is offline
Install a temperature monitoring program (Speedfan, Coretemp, etc) and see what kind of temperatures are happening. If they're nothing special, then it's probably not a heat issue.
But cleaning the case out never hurts.
