Old December 14, 2010, 07:46 PM
Smoothie's Avatar
Both Red (positive) and Black (Negative) are on the 4 pin molex. The 3 pin fan connector just has one blue wire. If I do not plug the 4 pin molex and have the 3 pin only, the fans do not run even if the dial is maxed (fan controller shows nothing for the RPM but shows the voltage). If I connect both 3 pin and 4 pin, I can see the RPM (3700) and the volts but when I turn down the dial the volts go down but the fan remains at 3700 RPM. Am I doing something wrong or am I just dumb? :P
Old December 16, 2010, 04:20 PM
Smoothie's Avatar
Yup, im dumb. I will have to remove the 4 pin molex and add pins plus the black/red wires and crimp them to the 3 pin and I should be all set.
Old December 16, 2010, 04:28 PM
no worries man :) i fingered something was amiss lol/.
Old December 16, 2010, 04:36 PM
I wouldn't daisy chain deltas at all.
They are a high amperage fan iirc and your best to run 1 fan off each channel.
If you need more than 5 of those in a case you have some serious case modding problems.
Old December 18, 2010, 07:46 AM
Smoothie's Avatar
Nah I'll be fine, at most when these Delta's use on first boot is about 12.7 Watts then levels down to 12 watts which will run them at 3700 RPM. Daisy chaining two of them will do about 25.4 Watts on one channel on first boot. The Lamptron FC5v2 does 30 watts per channel so it will be fine. I will report back here once I modify these fans to have all the wires connected to the 3 pin.
Old December 31, 2010, 07:07 AM
Smoothie's Avatar
Update, I got he fans working with 3 pin only. They work fine when having two Delta's on one channel. Sorry I forgot to take pics.
Quick question for karaoke fans esperasoppa Off Topic 2 March 21, 2010 01:18 AM
Fan controller question + fans ADay2Long Air Cooling 1 May 21, 2009 04:20 PM
How-To: Make Homemade Fan Controllers arekieh Guides & How-to's 25 February 12, 2009 02:12 PM
Question about fan controllers… Gameplaywarrior Air Cooling 13 October 3, 2008 05:54 PM
fan question 2x120mm rad 2 or 4 fans? Somed00d Water Cooling 4 July 30, 2007 11:08 PM
