<~----> Silent AM3 cooler - Hardware Canucks
Old November 24, 2010, 03:47 PM
Default Silent AM3 cooler
I recently upgraded my CPU with a AMD 965 cpu, it is working great. The only issue is that the stock fan sounds like a jet engine. I don't think i have ever head a fan so loud before.
I've asked around the local shops and finding a quiet alternative is relatively easy. My issue is i want to find a socket AM3 fan that uses the bracket already mounter on the board.
Are there any recommendations for a quiet / silent Socket AM3 fan that uses the standard bracket that work with the stock fan?
Nick
Old November 24, 2010, 03:52 PM
Soultribunal's Avatar
Zalman CNPS9900 is one of my all time favorites for cooling and quiet on a CPU.
They are somewhat expensive but worth the investment.
That or get the new Zerotherm 90 thats out.
ST
jcmaz's Avatar
Coolermaster 212+ or Sunbeam Core Contact if you can find one...
-Plato
Old November 24, 2010, 04:07 PM
and get yourself a fan controller or use the motherboards utility to control the speeds. if you are not overclocking turning down the stock cooler will help tons
Old November 24, 2010, 04:25 PM
sswilson's Avatar
The stock AMD cooler barely keeps temps under recommended max when you let it run full out, I wouldn't recommend lowering the default.
Old November 24, 2010, 04:41 PM
martin_metal_88's Avatar
Arctic cooling freezer are good n cheap. Also small if size is a matter.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 24, 2010, 04:42 PM
I second that , Dan doesn't realize that its probably that loud because its running full tilt to keep things under control.
Going lower is a bad idea, getting something aftermarket is recommended.
ST
Old November 24, 2010, 04:46 PM
well, it depends on temps. i have a machine that goes over 80% if it reaches 50c.
drop everest in there and check your temps. you can drop vcore a notch and see if its stable with prime95 or the like. the stock cooler, for a number of years, is ok-ish. loud were the pentium preshotts with the cheaper non copper coler lower profile smaller fan they came with sometimes. those things were insane. depending on your revision, you can have your cpu running stock ghz with considerably less voltage, which does help.
Old November 24, 2010, 06:48 PM
sswilson's Avatar
Considering that the max recommended temps on these chips is around 55c (much lower than intel chips) that's what I'd expect.
The AMD cooler in spite of looking pretty impressive just doesn't cut it.
Old November 24, 2010, 06:56 PM
I don't think many people read, lol.
CAN you get a cooler that works with the stock cooler bracket?
either way I have a Cooler Master Hyper 212+ . Around $20, and the included fan is pretty quiet. also 18 C cooler.
Silent Pro Gold Series Power Supplies from Cooler Master FiXT Press Releases & Tech News 3 June 2, 2010 07:39 PM
[FS] Antec P180 Case, Gelid Silent Spirit CPU Cooler element291 Buy/Sell & Trade 28 February 13, 2009 08:10 AM
Cooler Master Announces Silent Pro Power Supply Series MAC Press Releases & Tech News 0 June 17, 2008 09:07 PM
