Old November 24, 2010, 07:08 PM
Originally Posted by LarkStarr View Post
I don't think many people read, lol.
CAN you get a cooler that works with the stock cooler bracket?
Pushpin HSFs should work. The Scythe Yasya is very good in terms of noise and it performs extremely well considering pushpins make pretty low performance mounting systems. You should be able to get one for ~$40.
Old November 24, 2010, 07:12 PM
that would require removing the bracket.. I forget if you have to get underneath the motherboard for that or not. (yes?)
In which case you might as well install a proper bracket.
Old November 24, 2010, 07:49 PM
http://upload.wikimedia.org/wikipedi...Socket_AM3.jpg
Shouldn't have to, the screws are all on top, the backplate is bolted on. Most "proper" brackets won't have a backplate for AM3 sockets anyhow, as the socket itself has one.
EDIT: pic is kinda big
Old November 24, 2010, 07:52 PM
right right I remember now, but you have to get to the backplate anyways, still requiring backside access.
Old November 24, 2010, 08:04 PM
Soultribunal's Avatar
Either of the solutions I posted will mount without any removal.
ST
Old November 24, 2010, 08:18 PM
good call, but wasnt it a bit higher like 75? i know the new intel chips can go another 20 over that easy without burning up, at least in the short term.
still, he probably needs to do something before the 212+ or v6gt reaches him.
the same exact thing i did bout 30 minutes ago on some dudes puter who is waiting for a better cooler in the mail. amd chip, quad core,c2.
dropped vcore a tad, and put the fan at max 75%. he can now hear what other people are saying :)
Old November 26, 2010, 08:03 AM
Thanks for the feed back.
I am planning to go with the Zalman CNPS9900, seems like it has everything i need, and not having to remove the motherboard from the case is much appreciated. Ive had Zalman fans in the past and they have always worked well.
Nick
Old November 26, 2010, 04:00 PM
Nick
I've had 3 CNPS9900 since they came out. Still going strong , I think You'll be happy with the arrangement.
ST
Silent Pro Gold Series Power Supplies from Cooler Master FiXT Press Releases & Tech News 3 June 2, 2010 07:39 PM
[FS] Antec P180 Case, Gelid Silent Spirit CPU Cooler element291 Buy/Sell & Trade 28 February 13, 2009 08:10 AM
Cooler Master Announces Silent Pro Power Supply Series MAC Press Releases & Tech News 0 June 17, 2008 09:07 PM
