Old October 25, 2010, 04:51 PM
FlyingFish's Avatar
Default Cheap quiet alternative to stock 775 heatsink
My dad has a system with a nice crispy Pentium D 820. I want to replace the HSF with something a bit quieter, and preferably cheapish. Performance isn't a big issue as he isn't about to OC this to 4ghz or anything like that.
I hear the AC7 Pro is a good option anything else?
Old October 25, 2010, 04:58 PM
The AC7 Pro is an excellent option... I have several of them running in my machines... they are quiet, provide excellent cooling and are dirt cheap ($25. or less.) The Cooler Master Hyper 212 Plus 4 is also an excellent cooler... they run around $30.
Old October 25, 2010, 08:24 PM
headsh0t's Avatar
Just go for the AC7 pro if he isn't oc'ing. His case may not even fit the CM 212.
Old October 25, 2010, 09:36 PM
jcmaz's Avatar
I'd rather get the CM Hyper TX3 CPU cooler. It is ~$20 when not on sale.
-Plato
Old October 25, 2010, 09:49 PM
FlyingFish's Avatar
I appreciate all the replies, (and PM)
After poking around, I stumbled upon the OCZ Vendetta 2 which I already use in my main machine.
Buy OCZ Technology [OCZTVEND2] OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA
13.79. I don't think you can beat that
Old October 25, 2010, 09:55 PM
jcmaz's Avatar
Very nice!!!
Just be aware that the rubber grommets on that thing are extremely difficult to install.
-Plato
Old October 28, 2010, 01:05 PM
Do yourself a favour get the bracket kit. For the vendetta those plastic legs are flimsy
Old October 28, 2010, 01:23 PM
Dar_ell's Avatar
Yea the plastic pins are horrible, i bought the bolt thru kit from ncix.
"My brother is dead. He's not here Anymore. But on my back, and in my heart...He lives on in me. I will make a hole through heaven itself, even if that hole becomes my grave. As long as I break through, I will be victorious.Who the **** do you think I am?"
Old November 19, 2010, 11:26 AM
Trial Member
Cheapest thing to do would be to get a Scythe or Noctua FDB fan and mounting brackets (I just made my own lol) and mount a new fan on your current heatsink. Then just plug the fan into your onboard fan controller and use a fan controller or speedfan to regulate fan speeds.
Old November 27, 2010, 10:54 PM
OJX OJX is offline
Originally Posted by EdHilario View Post
Cooler Master Hyper 212+ is a great bang for the buck option. Usually retails for $30 but can be had for $20 if it's on sale.
I'd get this. The 92mm fan on the Freezer Pro doesn't seem like a worthy upgrade for the hot beast that is the Pentium D
Need Quiet / Silent Heatsink slay3r Air Cooling 5 June 11, 2010 01:57 PM
[WTB] quiet GPU or aftermarket VGA-Heatsink Cowboy Buy/Sell & Trade 24 January 25, 2010 08:51 AM
[FS] 775 CPU, mATX Heatsink Caldezar Buy/Sell & Trade 1 January 21, 2010 12:24 AM
[WTB] Great Cheap Folding GPU (nVidia) and Cheap 775 Mobo Arinoth Buy/Sell & Trade 28 August 28, 2009 07:10 AM
OCing q9550 on stock heatsink? ricknash61 Overclocking, Tweaking and Benchmarking 2 September 3, 2008 06:21 PM
