Old December 16, 2007, 06:53 PM
mattydies's Avatar
Default Air Cooling - Case pressure
I was wondering what affect pressure has on air cooling
Negative pressure, neutral and positive case pressure DOES Case pressure affect a systems temperature/cooling ability?
Matty
Old December 16, 2007, 08:32 PM
Matty
positive pressure in the case will keep the dust out
Old December 16, 2007, 10:01 PM
MpG's Avatar
MpG MpG is offline
Air is air is air. One way or another, you need it to enter the case, come in contact with the hot components, and then leave as quickly as possible. Generally speaking, this is best done with a near-equal balance of intake and exhaust fans, where the intake fans are aimed directly at the hot components, and the exhaust fans try to pull air directly away from those same components.
The dust prevention argument for positive pressure only applies if all the intake fans are properly filtered.
A common argument for negative pressure is the "scavenging" effect, where air is pulled from all the hidden corners that fans might not blow on directly. Nice, but the theory is dependent on there being holes/gaps in those hidden corners, through which air can be pulled in.
Old December 18, 2007, 10:23 PM
mattydies's Avatar
Well the Scavenging effect does sound nice, but I think my efforts would be better used for getting cold outside air directly to the hot components and then away quickly.
Thanks for the input
Old December 18, 2007, 10:30 PM
werty316's Avatar
Unless you aren't using filters, dust will get no matter if a case is setup for negative or positive air pressure.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Positive vs Negative Pressure? RCKage Air Cooling 2 March 16, 2008 03:27 PM
Case Cooling and Airflow - How much does it matter CasheKicker Air Cooling 18 March 14, 2008 09:30 AM
Looking for a M-ATX case with liquid cooling and mod-ability Nate_The_Great Cases 4 March 6, 2008 04:12 AM
Mid-tower water-cooling case? 3.0charlie Cases 13 October 31, 2007 06:07 PM
mesh for case cooling magictorch Water Cooling 2 September 18, 2007 04:12 PM
