Old October 11, 2010, 12:57 PM
homer98's Avatar
Default Different core temps
Hey all, just got a CM Hyper 212+, running an i7 930. When checking temps, the first core(0) seems to always be higher than the last core(3) by atleast 4-5C, when full load is applied, the difference gets up to 8C.
Is that normal? or should I expect more even temperatures across all the cores? Could there be less thermal paste on a certain area of the cpu? im pretty sure I seated the heatsink well and applied the TIM appropriately.
should I not worry about the temp spread or should I retry mounting the heatsink. Im happy with the temps I'm getting under load with an overclock, but not sure about the spread of the temps across the cores. Thanks for the help !!
Old October 11, 2010, 01:26 PM
It's normal.
Old October 11, 2010, 01:34 PM
Totally normal.
Old October 13, 2010, 06:08 AM
I think it's normal. On my i7 system there's usually a 7-8 degree difference in idle temps for me...you should feel lucky
Old October 13, 2010, 07:23 PM
homer98's Avatar
Heh, alright then. I will just accept it and carry on enjoying the i7 goodness :P
SLI 260gtx (192 core) & 260 gtx (216 core)? Possible? Apathetik Video Cards 5 September 22, 2009 08:06 PM
Big differences between core temps Skruch CPU's and Motherboards 5 January 25, 2009 07:34 PM
E8400 - Core Temps Lower than CPU Temp Capt Proton Water Cooling 0 January 25, 2009 03:32 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
E8400 Core temps - OCZ Vendetta 2 cooling Dwayne Air Cooling 8 August 17, 2008 01:13 PM
